7 members (FAST55, TUTS 59, Wally / Montana, Wickedbass, Mike Burns, Gdads51, Donf), 85 guests, and 4 robots.
Topics128,065
Posts1,055,870
Members48,428
Hi folks,
Quick question on clutch alignment. The manual indicates that the clutch should be installed such that the "X" mark on the clutch matches up with the "X" mark on the flywheel. Problem: while I clearly have an "X" mark on the rim of the flywheel, I don't have such a marking on the clutch pressure plate. There are two punched marks on the rim of the clutch: one looks like a "C", the other is clearly a "6"--I'm wondering if one of these is my reference mark? Thanks for any input on this!
PS: this is an 11" clutch going onto a 1953 235 engine.
1953 3600 Pickup
1946 Fleetline Aerosedan
1948 Hudson Commodore
Those markings were only valid for the original clutch assembly that was installed when the vehicle was new. Even then since each part was balanced individually, it was simply some engineer's pipe dream to insist on a specific assembly procedure. Once the clutch and pressure plate was changed the first time, probably decades ago, the marks became meaningless.
Thanks Jerry. So what I'm hearing in your reply is it doesn't matter?
1953 3600 Pickup
Not at all. I've done dozens, maybe hundreds of clutch/pressure plate replacements, and never paid any attention to the clocking of the flywheel/clutch cover. Other than getting a clutch disc installed backwards a time or two, no problems!
