5 members (Oswald, 55shaker, Barney1951, Otto Skorzeny, WICruiser), 83 guests, and 0 robots.
Topics128,050
Posts1,055,646
#1436215 01/05/2022 11:18 PM
I have a 1949 3600. I'm planning on rewiring to 12V system. I'm a novice at wiring. What is the best wiring harness available for these trucks? Thanks
Justice #1436226 01/06/2022 1:40 AM
Are you restoring or doing a hotrod? If just going with stock get one with as few circuit as possible but if you are adding a bunch of accessories like a big stereo, running lights, A/C, etc, you will want one with a lot more circuits. Outside of the restoration harnesses they are pretty much the same. Each wire is marked every few inches with where it is going. Spending a bunch of money might make you feel better but it’s not necessary. Good luck.
Justice #1436234 01/06/2022 2:07 AM
If your wiring is in good shape you don’t have to rewire to change to 12 volt.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Justice #1436252 01/06/2022 3:34 AM
Justice If possible would stay with original wiring it is plenty heavy for 12 volt,as kevinski said. Install a 1-wire alternator it only ttakes 3 wires to the rear of the truck to get everything done if you use a 9 wire turn signal switch. Your starter will work fine as is really whip over,change bulbs to 12 v and you've pretty well got it done. Might add a few fuses. The trouble with wiring harness is you have the firewall insulation in the way and other obstacles. The Guide brand turn signal switch (which is what the chevy dealer would have put in) works good ,may be kind of hard to land one not as many around now. Good Luck with your truck,we'll help as best we can !!
Justice #1436255 01/06/2022 3:39 AM
Justice Gotta change you coil unless you go to HEI or some other ignition .
Justice #1436279 01/06/2022 1:29 PM
O Online: Content
If you want to keep the stock look under the hood, You can buy a PowerGen 12v alternator that mimics the appearance of the original Delco Generator. No modifications to the brackets are needed as the ears are all in the same place.
They even sell 6v alternators that look like 6v generators
https://www.speedwaymotors.com/shop/powermaster-powergen-alternators~8193-10033-363
1950 Chevrolet 3100 (Ol' Roy)
Otto Guess I am not a purist as an alternator and the big HEI look good to me,also use a lot of aluminum propane parts under the hood,I must be the onlyy one in America that burns propane !
Justice #1436288 01/06/2022 3:19 PM
Curmudgeon
Curmudgeon
....Red Light....
Be careful buying an alternator that is redesigned to fit or look like the standard generator.
Past versions have a cooling issue leading to failures (standard alternator diameter is larger, more cooling).
Maybe they have solved the problem by now but I would investigate before buying.
Also consider that the stock mounting location is near the exhaust manifold.
The standard alternator is much, much cheaper.
My opinion.
If you have furniture wood in the bed and/or radial tires, it doesn't make much sense to fret over the appearance of an alternator.
buoymaker When I first went to alt. about 67 soon learned to work on them,later an old guy that had done generators since 36 showed me how to really use them. This was before 1-wire. He explained how to use the right rotor to get one that would prime and continue to charge at a fairly low RPM-like these trucks!!
Justice #1437654 01/17/2022 7:45 PM
Curmudgeon
Curmudgeon
My red light comment was referring to the PowerGen or Gener-nator and possible overheating issues.
However, I do know what the "old guy" was explaining to you.
When you ordered a new truck, you could select from the RPO (Regular Production Options) to purchase different ampacity generators.
My engine came from a 6400 fire truck tanker that has a 55 amp generator.
Still working well today. No problems running a 6 volt system.
