5 members (TooMany2count, 1955 1 Series, Mike B, klhansen, Otto Skorzeny), 135 guests, and 3 robots.
Topics128,123
Posts1,056,653
Members48,450
I removed my intake and exhaust manifold to clean and evaluate and there is a big crack in the exhaust manifold, see pics below. I assume I need to replace it but figured I'd ask if it's repairable, or if it is, whether that's even a good idea. The crack wraps around most of the manifold although I cannot flex it by hand (I didn't try to snap it in case it can still be welded).
If I replace it, should I look for another old part or is there something new I can bolt in its place? The intake looks OK.
Riding in the Passing Lane
Get a good used one. They are all over the place.
George
1972 Chevy c10 Cheyenne Super
That crack is in just the right place to put in a divider baffle to make a split manifold for dual exhausts. Otherwise, look for a replacement. There are offshore "clones" of the old cast iron dual exhaust headers, but they're pretty poor quality and don't fit well. The supply of original equipment single exhaust replacement manifolds and the Corvette six cylinder dual exhaust system dried up years ago. Good condition used ones are available- - - -try a "parts wanted" post here, and search Ebay also.
Thanks. I posted a wanted ad and will look locally and on eBay as well.
When you get a new one and you are not going to do anything with the old one I would salvage the spring and the heat riser flap and weight in case you need it in the future.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Good tip thanks. Those are all in good condition and functional.
Henrythe wound You could bolt that to a head,take a blue blade (thin grinding wheel) cut it completely in two weld with stainless. The trouble is the casting has lost most of it's carbon and is brittle now. Like us we've lost most of our carbon at this age LOL. Best bet is find a clean,straight,not to rusty replacement. Have several but there 2000 miles away, and are well rusted !!
They’re so plentiful I don’t even save them anymore if I scrap an unrevivable engine. I live in the city and don’t need codes officials breathing down my neck over parts I don’t need.
I invest my money in precious metals, mostly rust!
It looks to me there is another crack at the 1-2 runner.
George
Last edited by Wrenchbender Ret.; 12/27/2021 7:13 PM. Reason: 1-2 runner instead of 5-6 runner
I bought one on Ebay a little while back. It was good but I had to get it planed. The part was nice but the shipping was a killer!
1951 1 Ton Completed
Weld it up
Try Muggy welding products.Works really good Amazon sells it
!956 Gmc Napco 4x4 Factory line built .
Donald S.
Donald S.
I have that exhaust manifold as i changed to dual exhaust and dual carbs on my 1953 that has a 235. Let me know if its something you might be interested in?[email]dcsjr472earthlink.net
[img]http://flic.kr/p/2mf6Bd6[/img]
1949 Chevy Carry All
Follow the resto in the Project Journals
1953 Chevy 5-window
"Frame off Restoration"
Follow the resto in the DITY
Beginning to End Slideshow
More images in Flickr
\|/\|/ Dual Ex. \|/\|/Dynamat
Please don't tell my wife how much this thing cost!
Buying, selling or giving away in the forums outside of the Swap Meet Forums is prohibited activity. Thanks
