| | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2021 Posts: 9 'Bolter | | 'Bolter Joined: Dec 2021 Posts: 9 | I have a two-part acrylic urethane I purchased approximately 10 years ago to paint the frame. It has been stored in the garage unopened. I have the paint, the activator and the reducer as well as the mix ratio. They specify a 18 - 2.0 spray tip. I only have a 1.3.
Should I try it or would I create a mess for myself? | | | | | Joined: May 2015 Posts: 11,004 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,004 | The paint I have (bought in 2019) which is an acrylic enamel specifies a 1 year shelf life on the Data Sheet. I just painted my engine with it without problem. It's unactivated and no reducer needed.
My opinion (which may or may not be worth 2 cents) is that you'll probably be OK if the storage conditions aren't too hot. I think cold is a better storage condition.
Since you're painting the frame, which won't be seen easily, you'll likely be OK. You may have to reduce it a little more than the spec says to use the 1.3 tip. You'll get a finer spray with it, of course.
If it were me, I'd do a test panel and see how it works before committing to your actual project.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2010 Posts: 2,306 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,306 | Stir it really good and flip a coin .good idea to test first .I had old paint before that just would not dry but it looked good nice and shinny like wet paint oh it was wet . | | | | | Joined: Mar 2014 Posts: 4,479 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,479 | I had some PPG Deltron left from 1989 that was still usable last summer. The hardener had gone bad, but I discovered I could use common hardener made for urethane paint today just as well. Try it first, but you may be surprised to find it is okay. This Deltron had been stored in the garage since 1989...hot, cold, whatever. I had black, white, clear left from a 1957 Bel-Air I painted. 1.3 tip is pretty small, however. As Kevin said, you'll probably need to cut it a bit more than normal.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
