2 members (J Lucas, pauld), 123 guests, and 2 robots.
Topics128,183
Posts1,057,263
Members48,467
I recently purchased a reproduction chevy truck grill guard. I noticed it tilts backwards when installed. Has anyone found a fix for this, to have the grill guard sit up straight?
My guess is that it’s made to have a slight slant to it. Probably less likely to fail when contacted by a deer if it has an angle to it instead of hitting it at 90 degrees.
Can you rotate the gaurd outwards or does the bumper cut-out fit only one way?
Great looking gaurd with the shiny new bumper and paint!!
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
It is in the cut of bumper guard, it tilts back as you tighten the bolts. I was thinking of making rubber spacer to go between the guard and the bumper.
There’s a truck in the Gallery Forum, My Girl Red, that has a similar guard. It sits straight up on that truck. You may want to contact the owner of that truck.
Dan
35 CC Case
38 Chevy Pickup
51 3100 AD
58 3100 Apache Fleetside
Professional procrastinator
What if you flipped the bumper over? Maybe it is not perfectly symmetrical?
1947.2 GMC 1/2T SWB panel
1947.2 GMC 1/2T long bed
1948 GMC 1/2T short bed
You stated that it is a "reproduction" grille guard--could that be the issue?
