8 members (Hanks custodian, FAST55, Rusted Nut, Otto Skorzeny, Gdads51, Bill Hanlon, TexasA&M48Truck, John L.), 82 guests, and 3 robots.
Topics128,075
Posts1,056,003
Members48,433
#1434220 12/20/2021 8:11 PM
Im curious if this is a home made hood stay or an item i can order somewhere.
It is a hood support. you can get one like it from:
https://www.robertsmotorparts.com/search?q=T162
If you want the correct one for the Chevy truck you can buy them at:
https://www.classychevusa.com/index...245/category_id=35/mode=prod/prd1245.htm
Or, you can make your own by using the sttached information.
https://www.stovebolt.com/techtips/hood_prop.pdf
Note, if you use the "flat" prop, you will have to move the Voltage Regulator down about 1" for clearence of the support in the closed position.
Harold
Harold
Thanks for the information. Much appreciated
This one is easier to build, a couple pieces of sheet metal, 2 bolts, a hitch pin clip, a rubber tip, and a piece of whatever round stock you can find. Pictures are not very good but all I have now.
Harold Wilson
41 Chevy 3/4 Ton
