1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2021 Posts: 9 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 9 | Good evening,
I am currently rewiring my '46 1.5 ton and I am looking for a wire diagram if anyone has one available to share.
Thank you | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 |
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2021 Posts: 9 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 9 | Thank you. This should help. It is a harness from Jim Carter Trucks. | | |
