0 members (),
45
Mod | | | Forums66 Topics128,049 Posts1,055,637 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 32 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 32 | Looking for upper and lower radiator hoses for my 54 Coe. I have ordered a few different but they never fit. Was wanting to see if anybody might have a part number or insight on where to get? It currently has the 261 with stock radiator.
1954 Chevy COE 1948 Metro Van 1979 RH drive mini cooper
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Dodgecummins, my Dayco catalog lists upper 70541 or 70081, lower for that application is not listed, all other applications call for 70015. All hoses show 1 1/2" in and out. 70541 and 70015 are out of stock at RockAuto 70081 is $9.97, Merry Christmas, hope that helps. | | | | | Joined: Jul 2014 Posts: 32 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 32 | Helps a ton, thank you and have a Merry Christmas also!
| | | | | Joined: Sep 2012 Posts: 103 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 103 | you also can fabricate some copper pipe and use the hose at each end. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Dodgecummins I turned out some stubby hose splices that are 2 sizes and you can swivel the hoses. With these you can use any hose at your local FLAPS to get what you need. If hoses bomb on the road any local flaps can help you get out of the woods,pocket knife and a screwdriver anti-freeze and your back on the road !! | | |
