4 members (ronsway, Wally / Montana, 2 invisible), 148 guests, and 6 robots.
Topics128,078
Posts1,056,052
Members48,433
Q
Q Offline
I am restoring a 57 1/2 ton. I am reconnecting the original gauges. The oil gauge is the mechanical gauge with the copper pressure line running from the engine, through the firewall and into the oil gauge. Quick question: does the copper line need to be primed with oil (air flushed out of it) prior to installation?
No. Pressure is pressure whether it's air or oil. It won't matter if there's air in it or not. The needle might bounce just a little bit on initial pressurization, but even that won't be a problem.
Q
Q Offline
thank you
