7 members (GMCJammer51, D B Cooper, treegrower, 2-Ton, 55shaker, Phak1, 1 invisible),
132
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,095 Posts1,056,072 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2021 Posts: 25 'Bolter | | 'Bolter Joined: Sep 2021 Posts: 25 | I am restoring a 57 1/2 ton. I am reconnecting the original gauges. The oil gauge is the mechanical gauge with the copper pressure line running from the engine, through the firewall and into the oil gauge. Quick question: does the copper line need to be primed with oil (air flushed out of it) prior to installation? | | | | | Joined: May 2015 Posts: 11,060 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,060 | No. Pressure is pressure whether it's air or oil. It won't matter if there's air in it or not. The needle might bounce just a little bit on initial pressurization, but even that won't be a problem.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2021 Posts: 25 'Bolter | | 'Bolter Joined: Sep 2021 Posts: 25 | | | |
