4 members (DaveV, moparguy, dunfire, Bills Auto Works), 66 guests, and 0 robots.
Topics128,049
Posts1,055,680
#1433262 12/12/2021 5:47 AM
When I got my truck all the brake lines and clips holding them on were removed. I running new 3/16” lines (all disk) and when looking at LMC for clips the diagram depicts clips that screw in. The assembly guide shows the 3100 has clips that squeeze in from what I can tell. Anyone know where to get clips for 3/16 line that will fit in original locations?
Thank you
1950 Chevrolet 1/2-Ton 3100
My truck has clips that look like this along the frame rail but these guys don't have 3/16 clips.
A little more searching turned up these and these
A guy could go broke buying enough of these for a single truck. big_eek
The clips for the line crossing at the rear engine mount and front crossmembers (bolt on style) are available from the Filling Station and other vendors.
Klhansen, wow, those are crazy prices for a single clip, do they take monthly i installments? Lol.
Once again thanks for your help.
As stated, when the prices went insane I made our own clip making tool; something anyone can do with regular home garage tools. You can use any metal you care to and make any width up to about 3 inches. Wide one is for fuel line on old flathead Fords. Cost is probably under a nickel and time is about 20 seconds per clip. I posted a how some time back to but if it cant be located I'll do another.
Evan
Insomniac
Insomniac
I used the clamps designed for holding electric cables. Bought a package of them and used them for holding the wiring harness in place as well as brake and fuel lines.
https://www.amazon.com/TICONN-80PCS-Cable-Clamps-Set/dp/B094YP2F3D/ref=psdc_3207129011_t4_B07V2YBDS5
Of course, if you insist on originality they won't work for you.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Thanks Coilover, I assume the link to the video was posted in this forum? I would definitely be game to try making them and will look for the video.
Thank you
Not going for originality but more for simplicity and not having to drill new holes in the frame. I do like that those clamps are rubber lined and way cheaper. Did you screw them into the frame?
Thank you
Thank you
You should be able to use the original holes in the frame using a small bolt and nut. The lines might be in a slightly different position, but as long as they don't run into something, it should be good.
Dongray #1433344 12/12/2021 11:43 PM
Crusing in the Passing Lane
Those(with the rubber inside) are called Adel clips, used in aircraft also.
Ed
Dongray #1433353 12/13/2021 12:23 AM
Insomniac
Insomniac
Kevin is right. I use a small bolt and nut to hold them on. Occasionally you need need to use a sheet metal screw if you can't get behind the mounting surface to hold a nut on.
Gord 🇨🇦
