0 members (),
134
Mod | | | Forums66 Topics128,193 Posts1,057,258 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | Does anyone have any pictures of the rear wheels of a 1953 3600 3/4 ton truck. My truck never had any rear wheel components for the emergency brake. I had to buy all new replacement parts. Now I have to put them together. But I'm not sure on how it goes together. Any pictures would be great to have, Thanks in advance.
Inside the rear wheels where the brake shoes are. There is the lever that Has the spreader bar for the E- brake. On that spreader bar there is a spring And there is also the cable that attaches to the lever for the E- brake. I just need a picture showing how all that is connected together. Elmo
| | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | Do you have a huck or bendix brake system? Can you post a picture of your parts?
Mike Barnes 1950 GMC 1-ton pickup
| | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | Bendix. I will post pics tonight.thanks
| | | | | Joined: May 2015 Posts: 11,168 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,168 | The parking brake arrangement for a 3/4 ton should be the same as the half ton. Check this illustration. That should help you figure out how they go together.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | Thank you, Klhansen!!! You don't know much I appreciate this picture.
Elmo. | | | | | Joined: May 2015 Posts: 11,168 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,168 | Thank you, Klhansen!!! You don't know much I appreciate this picture.
Elmo. Don't thank me. Thank Keith Hardy for putting that stuff online. I just tracked it down for you.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | I just thanked him. But I appreciate the fact that you found the information that I was looking for. So thank you so much for taking the time to find what I needed. Elmo | | |
