3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#1431784 11/30/2021 3:47 AM
I am going to paint my project burgandy and. What primer color would work best? I have the option of black white or grey. At this point I think I will go with bc/cc. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
I'm no expert, but with a dark color, either black or very dark grey would probably be best.
I did a quick search and came up with this.
Good article, thanks.
1941 Chevy
Moderator, Electrical Bay
If you use dark primer, you can get some light primer to use to check for high/low spots (a guide coat) before you paint. And vice versa...dark over light. And if you're using a high build primer (which you should be using), you can actually fill shallow differences with it.
~ Jon
Ex Hall Monitor
Ex Hall Monitor
As a general rule if your topcoat has a lot of pigment you can use any color primer or sealer you wish. If your topcoat is leaning toward the see-through candy spectrum you want a color that is in the same family and you want to not have any dark or light spots.
homer52 #1431890 12/01/2021 12:32 AM
7
7 Offline
I recently painted some of my 22.5" wheels, I had them sandblasted then I used PPG epoxy primer in medium grey, color coat is PPG acrylic urethane in black, two medium coats and completely covered the grey.
