1 members (SlimSix),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 68 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 68 | Any thoughts on the use of some of the popular fuel system cleaners in our stovebolts. Although I have had good results using carb cleaner sprays on dirty linkages, wondering if any of you have used the fuel system additives to clean internals to keep floats, accelerator pumps and needle valves clean and working properly. The float occasionally sticks on our 1952 1/2 ton Chevy 235 with a Rochester carburetor and floods. This happened twice this past summer although the flooding stopped after working the throttle. Wondering if a fuel system cleaner may help this problem. Any thoughts or experiences would be appreciated. Chuck 52 | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | I always had good luck with seafoam.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Jul 2000 Posts: 2,191 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,191 | I've tried the magic potions over the years. Pouring stuff down the carb throat while running or adding stuff to the gas tank. Never works - always ended up disassembling and cleaning the carb.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Sticking floats is usually dirt in the fuel. Use aux. filters. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | Avoid ethanol as much as possible, try not to let it set for long periods of time with ethanol.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | I found the opposite situation, but gas is produced regionally with a lot of variation so both our cases are anecdotal
Old days gas go bad after a while for me but the Modern ethanol blends in Saskatchewan let me abandon my trucks for over a year I get in and crank and it’s fires up after the pump primes the carb My old farmall starts even better it doesn’t care at all Ethanol is a very stable molecule it cannot decompose spontaneously without heat or light so it makes sense Ethanol can also be used instead of formaldehyde to preserve tiny things In glass jars but it’s not as great Something else in the gas is breaking down and causing issues but it is not the ethanol If ethanol could go bad you wouldn’t want to drink old whiskeys at the liquor store -s | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | The Techron stuff that they used to put in Chevron gasoline in the old days had a good reputation. So I use the bottles of Techron that I can add when filling up. And I can buy it at Costco. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Chuck 52 The best fuel system cleaner I have ever used is propane,most of my AD'S are on it straight. Now it takes some management cause if you run it out kind of inconvenient but you can save it with a 20 lb. cylinder. LPG is clean,no fuel pump,carbs are simple,you can have fuel at home,NEVER cold natured,oil stays like new,no sludge have used it for 40 years. all of my AD'S are on it,along with my 04injected GMC does both !
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Wally Montana If you recall mobil had an upper cylinder lube that came in like a little oil can,my Dad liked it,that's been 55 years ago . | | | | | Joined: Sep 2010 Posts: 68 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 68 | Thanks to all. Appreciate greatly the sharing of experience and advice. Happy Thanksgiving! Chuck 52 | | | | | Joined: Feb 2004 Posts: 29,774 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,774 | Carb King's term "deathanol" is a good one. The stuff is hygroscopic (absorbs water) so if it sits for any length of time in a gas tank anywhere except maybe the Mojave desert, it's going to get corrosive. That white powdery residue that clogs up carburetor passages in one that sits idle for a while is caused by moisture. I wonder how it got there? I've had pretty good luck with using Sea Foam in the gas tank of my Harley when it doesn't get ridden for a few months in the winter, but I also run non-ethanol gas whenever possible. Jerry
| | | | | Joined: Sep 2010 Posts: 68 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 68 | Thank you, Jerry. Very fortunate to have no-ethanol gasoline available here in West Michigan. With having four stations within 10 miles in each direction I have not had to use ethanol in many years. With our pickup generally running well with the exception of the very occasional flooding situation probably just a bit of cleaning needed for our carburetor. Again, thanks to all and hope your Thanksgiving was joyful. Chuck 52 | | | | | Joined: Feb 2004 Posts: 29,774 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,774 | Our turkey turned out dry and tough, desspite taking all the usual precautions to prevent that from happening- - - - -rumor has it that Butterball skipped an important step (that the PC Patrol won't let me mention) this year! Jerry
| | | | | Joined: Jul 2000 Posts: 2,191 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,191 | Our turkey turned out dry and tough, desspite taking all the usual precautions to prevent that from happening- - - - -rumor has it that Butterball skipped an important step (that the PC Patrol won't let me mention) this year! Jerry So that dry, tough turkey cleaned your fuel system? Let's not go there.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | Avoid ethanol as much as possible, try not to let it set for long periods of time with ethanol. I found the opposite situation, but gas is produced regionally with a lot of variation so both our cases are anecdotal
Old days gas go bad after a while for me but the Modern ethanol blends in Saskatchewan let me abandon my trucks for over a year I get in and crank and it’s fires up after the pump primes the carb My old farmall starts even better it doesn’t care at all Ethanol is a very stable molecule it cannot decompose spontaneously without heat or light so it makes sense Ethanol can also be used instead of formaldehyde to preserve tiny things In glass jars but it’s not as great Something else in the gas is breaking down and causing issues but it is not the ethanol If ethanol could go bad you wouldn’t want to drink old whiskeys at the liquor store -s As someone who spent his entire career in the petroleum industry (and lived in SK) I must interject. There is a reason ethanol is not allowed in aircraft engines. Ethanol is hydrophilic - it absorbs moisture from the ambient air. Ethanol is also highly corrosive; it literally digests any rubber components in antique vehicle fuel systems. My company spent millions replacing virtually all their pumping equipment after the ethanol blends dissolved the seals into swollen blobs of goo. After witnessing this, and being an airplane pilot, I won't let ethanol fuel touch any of my vintage cars, especially if it's going to sit for any length of time. To find stations that dispense ethanol-free gas in your area visit this web page: https://www.pure-gas.org/
1951 Chevy Panel Truck
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Our Costco quit carrying the Techron. Our Walmart has it. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
