0 members (), 209 guests, and 3 robots.
Topics128,266
Posts1,058,368
Members48,485
#1429829 11/11/2021 2:53 PM
1958 GMC 1/2ton 6 lug front disc brakes
What years will fit to appear original?
Thanks in advance
Danny
1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
Curmudgeon
Curmudgeon
Sorry we didn't answer your question in your previous post:
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1380689/1958-gmc-rims.html#Post1380689
Working backwards.
Original 1958 GMC had hubcaps.
The 1958 GMC rim had clips to hold the hubcap.
Beginning around 1962, rims have nubs instead of clips (old design...hubcaps becoming airborne).
Old style hubcaps do not fit 1962 and newer rims.
Rims designed for radial tires began around 1965.
Front disc brakes for Chevrolet light trucks began around 1971.
Begin your search for 1971 onwards.
http://www.boltpatternfitment.com
If you have the $$$ there are companies that can widen orignal rims and weld-in new style beads for radials.
