2 members (ranchojuan, baldeagle), 35 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#1428449 10/29/2021 11:19 PM
Can't find the thread now but some time ago there was a post on electrolock ignition & I mentioned I had a tool. Someone wanted to see picture. So here it is, years later.
NOT for sale.
BC
1960 C60 pasture art
Moderator, please remove this thread. It is not fair that he has one and the rest of us don't. AND he won't sell it!
Also this is a family friendly site and these photos are borderline ****ography (edited for the sake of the children).
smile
So what is it? I didn't see the original thread and it is an interesting looking thing, but I am not clear what it does.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
AD Addict & Tinkerer
My guess is it’s for Chevy distributors. It’s got everything you need. A feeler gauge, screwdriver, two different sized tools for split nuts like the one’s on a 216-235-261 distributor and a scale to boot!
Phil
Project Journals
Stovebolt Gallery Forum
BC59 Don't sell it's the Holy grail,that is a real dandy !! I don't covett it too much cause I use alternator and HEI ignition. It is a rare and fun item to show to your pals !!
52 Carl Take it easy your turn is coming ,if you can live another hundred years !!! LOL
Thank you for your condolences.
It came from my mom's stepfather, he gave my a bunch of tools when I graduated from high school. He was an old time mechanic / machinist. An old friend whose father was his buddy told me at one point he would go to shops around the Portland area turning crank rod journals, babbitt & resize rods to fit then on to the next shop to do the same. He had carbon monoxide poisoning, would have to put on a gas mask to be anywhere near exhaust. got better near the end of his life but I have always been the shop nag, "put a hose on it!" Still use several of his tools but have never seen a electrolock system up close.
BC
BC59 In about 1970 I finished off the portable grinding era like you described,the high compression engines were just too much for a portable grind to work. Had a hand lathe that would bore babbitt rods slick as could be any size too. Took me a while to figure it out,we had a bin full of semi-finished 216 rods. Wish we had em now--however we can't live in the past forever !! LOL
Massey-Ferguson Perkins Diesel rod bearings work in bored-out Babbit rods- - - -STD diameter Perkins bearings are 60 undersize, so those worn out 30 under crankshafts can be salvaged. I use a milling attachment to hold the rods and a micrometer boring head in the spindle of my lathe to bore the rods a few thousandths undersize and finish off the bearing bore with a Sunnen hone.
