0 members (),
101
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2021 Posts: 15 'Bolter | | 'Bolter Joined: Sep 2021 Posts: 15 | Hi guys, can anybody tell me the best place to find return springs for a 1938 11/2 ton? Also think I better rebuild the brake cylinders if I can get the kits? I hope this is the place to post this message. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Oilyrider1951, welcome, Jim Carter Classic Truck Parts lists the rear brake return spring as their part number ME148. Wheel cylinder overhaul kits, front their p/n ME134, rear their p/n ME935. I will not quote prices as my catalog is an old one. They also stock new wheel cylinders if yours turn out to be not repairable, good luck with your project | | | | | Joined: Sep 2021 Posts: 15 'Bolter | | 'Bolter Joined: Sep 2021 Posts: 15 | Tnx 3B, Ill take them off and apart to see if they are salvageable. | | |
