5 members (Gib70, moparguy, Hotrod Lincoln, artinva, Bill Hanlon), 80 guests, and 2 robots.
Topics128,078
Posts1,055,935
Members48,430
#142738 07/21/2004 12:34 AM
I can pick up a 1969 six cylinder for about 70 dollars, and it runs and is good shape. Will this go in my 46 one and a half ton with a minimal amount of trouble. Or is it even a good motor, for that matter what is it? Thanks for the help guys
Hudson
#142739 07/21/2004 12:51 AM
Anonymous
Unregistered
Anonymous
Unregistered
Assuming you are talking about a Chevy 6-cylinder it would most likely be a short deck 194,230,250 or a tall deck 292 . . . you can tell it is a 292 if the side covers over the lifters / pushrods are about 6 inches tall. The short deck motors have side covers about 3-4 inches tall.
Casting numbers will tell you for sure.
It has the same bellhousing attachment as a small block chevy . . . the 292 has staggered motor mounts. Not a drop in / bolt in, but not a very difficult swap either. The easiest way to install will require a completely new drivetrain from fan to rear axle.
