7 members (mick53, Tiny, Southerntruck, HandyAndy, TUTS 59, 2 invisible), 82 guests, and 2 robots.
Topics128,093
Posts1,056,046
Members48,433
#1427067 10/17/2021 5:09 PM
I heard somewhere that when switching from 6 volt to a 12 volt system you may have a problem with the 12v starter pinion gear not meshing with the flywheel ring gear properly, has anyone heard this before.
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody
Yes a 6volt starter must go with a proper 6 volt flywheel with the corresponding tooth count.
1949 gmc 1-ton
I may be wrong but I believe 6volt needs 139 tooth and 12 volt is something like 168? Someone will correct me
1949 gmc 1-ton
3B Offline
Hy Blanch53, unfortunately the 6 volt and 12 volt starter armature shafts are different diameters, so a simple swap of starter drives is not possible. The six volt starter will survive quite well on twelve volts, providing it is in good condition and that is not used to crank the engine for excessive amounts of time. Good luck with it.
thanks for the replies and information, I have a 6v system with the 235. I have aquired a 12v starter and generator and want to make sure if I do convert that it is done correctly
Crusing in the Passing Lane
Like 3B said, if you want to use the 12v starter, need to change to 12v flywheel. 6v starters work fine on 12v, just don’t sit on the starter, no need to change flywheel.
Ed
Everyone has provided good/correct information on the switch over. One thing not mentioned is the faster spin of the 6 volt starter running on 12 volts. If you have a cantankerous starting Engine the faster spin can be a blessing. Another advantage is you don’t have to pull the transmission and clutch and change out the flywheel. Install your 12 volt generator and call it good. Stovebolt has a very helpful Tech Tip on 12 volt conversion. Search the Tech Tips at the top of the page.
There is a local shop in my area that does Alternator, generator, starter and water pump rebuilds for shops all over the U.S. Last time I talked to the guy he stated they send out about 40 rebuilt alternators a week. they have been in business for years and really know their stuff. I don't know if it is possible but if you want to go this directions I can send you their contact information and they could possibly rebuild and convert your 6v starter to a 12v starter using the existing pinion gear, avoiding a needed change of the fly wheel.
Dave from Northern Kentucky
My 54 3100
blanch 53 When you switch to 12 volt,electrically,it will make your starter whip over much better. switching mechanically is when parts can clash.
