| | | Forums66 Topics128,108 Posts1,056,239 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2021 Posts: 51 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 51 | Team I still got issues with my C10 starting.
My 64 has a 73 350 in it. Runs good and it's been my daily driver for 2 years ( actually sold my new f150 its my only vehicle now)
When I start it sometimes it will do the clicking then turn over slow, then finally catch and fire up. I put a new starter with cylinoid a week ago and it worked great. Yesterday it started the same thing again. I checked connections and all seems to be tight. Anyone have an idea what I should check to see what the problem is? I was thinking maybe timing but it runs pretty darn good.
1964 Stepside C10 "Well we didn't get all dressed up for nothing." ~ Braveheart | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Don’t rule out getting a bad starter.
| | | | | Joined: Oct 2021 Posts: 51 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 51 | True, I bought it at local parts store. Probably one from off shore.
Won't hurt to swap it again I guess. (Those are some heavy rascals )
Thanks for the advice
1964 Stepside C10 "Well we didn't get all dressed up for nothing." ~ Braveheart | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I lean towards something other than the starter.
1. Battery, Battery, Battery. 2. Battery cables. 3. Battery connections. Clean the posts and the clamps. 4. Ignition switch. 5. Wiring/miswiring. 6. Connections/terminals broken/loose. 7. Advise part number and vendor of new starter.
You say "still have issues with starting". This indicates you have mentioned it before? I don't see that. Please explain any history. Any wiring done. Any other parts replaced, etc. When did this happen and how long was it operating OK. The first step now is to have the battery checked by a professional.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2021 Posts: 51 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 51 | Bart, you win the prize. My neg battery cable went to frame I got a new cable put it to block. Starts like it just had a shot of tequila.
Thanks folks.
