5 members (HandyAndy, 2-Ton, 78buckshot, TUTS 59, Wally / Montana), 91 guests, and 2 robots.
Topics128,060
Posts1,055,835
#1426083 10/06/2021 11:40 PM
Just to clear everything up. Notch on rod bearings should line up. If notch from piston is on driver side than the bearing cup should match ? i have a mix match of bearings now. Thank you
1955 First series 3600 3/4-ton
"A Great Starting Point"
Follow the story and pix in the DITY Gallery
66flea #1426084 10/06/2021 11:43 PM
I use the search and it's still not clear to me. yet?
