Topics128,052
Posts1,055,725
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
Thanks ahead for any info. I bought a 37 truck a bit back. I am not happy with the Master cylinder placement on under side frame. I would like to know if any of you have a under dash Master cylinder/ Booster setup. I am hoping my engine firewall has enough clearance from steering column to mount it there. If not, I will go under dash. I am not a mechanic but I do have knowledge of mechanics.The name brands of under dash would be of help. Thanks
Crusing in the Passing Lane
Need to brace the firewall for added foot pressure at new master. Ed
From Kugel Komponents.
Picture 1. Hydro boost on firewall of 55.2 GMC, master bolts to front of this unit, Picture 2. Pedal assembly inside cab, look on ‘net, perhaps CPP. Ed
