2 members (baldeagle, Shardean), 31 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,422
#1424406 09/18/2021 12:57 AM
So I got this 52 GMC truck that was all apart when I got it. The firewall has a ton of holes in it. I'm working on the cab, I'd like to know which holes are supposed to be in there so I can weld up the ones that aren't supposed to be there.
Also the accelerator pedal pin is rusted in. The pin should slide out from right to left , correct? Trying to understand what holds it in place other than a single cotter pin.
Paul
1952 GMC
Starting with a basket case
In the Project Journals
1967 GTO
1967 Firebird
pauld #1424411 09/18/2021 1:25 AM
The accelerator pin does slide out from right to left. Mine was rusted in place. I used PB Blaster for about a week and then tapped it out with a punch.
Jeff Mather
pauld #1424413 09/18/2021 1:30 AM
AD Addict & Tinkerer
Here is a page from the 47-54 Factory Assembly Manual that I used for my 52 Chevy. I believe its the same as the GMC.
Phil
Project Journals
Stovebolt Gallery Forum
pauld #1424417 09/18/2021 1:40 AM
Don’t remember which way the pin slides, but there is nothing but the cotter pin holding it in place. Soak it down with penetrant like Liquid Wrench or Kroil, then you should be able to tap it out.
Phil
Project Journals
pauld #1424518 09/18/2021 10:58 PM
The pin can only come out from the left. The hole in the right side of the bracket is not round. That is where it is likely rusted tight. It is a snug fit when new.
pauld #1424850 09/21/2021 10:37 PM
Awesome firewall help. Thanks!
Soaking the accelerator pin
1952 GMC
1967 GTO
1967 Firebird
pauld #1425057 09/24/2021 11:39 AM
Only cavemen still weld firewall holes. Cut to size patches for all the holes, rough up around the holes on the inside of the firewall with 36 grit disc, rough patch up with 36 grit, butter around holes with 3M Panel Bond and stick patch in place. Next morning your DONE with no warping and about two hours total time. Panel bond holds together airliners and the 2000mph SR71 so it should be sufficient for firewall holes.
Firewall holes "bonded" 25 years ago---had 73 EXTRA holes:
[img]https://i.postimg.cc/rKbQzc92/dan-s-49-011.jpg[/img]
Evan
pauld #1425059 09/24/2021 11:47 AM
Evan, can I assume your making the patches bigger than the holes, bonding, then then filling the front with bondo?
Phil
Project Journals
pauld #1425691 10/02/2021 4:45 AM
Yes, patches are bigger but zero chance of rust since panel bond squishes out all around patch. One can even used the panel bond as a filler since the firewall is only .060 thick.
Evan
pauld #1425742 10/02/2021 10:38 PM
3M panel adhesive is wonderful to work with as Evan has described. It is like butter to work with, sets up hard, but sands out smooth as glass.
Its a little pricey, but so is welding and fixing warps.
pauld #1425795 10/03/2021 4:54 PM
Moderator, Electrical Bay
You can also use JB Weld's "Quik-Weld" in the same way if you are on a budget. It sets up faster and sands smooth also. Hold vertical patch pieces in place with common masking tape until the JB Weld is cured. I used the regular JB Weld to repair the seam between the roof and pillar on my 1952 40 years ago and still have no problems.
~ Jon
pauld #1425828 10/04/2021 8:01 AM
Yes, any two part epoxies will work. We have a case or magnets for holding vertical patches. My rating is:
Best---Marine Tex (expensive)
3M Panel bond (designed for the job)
JB Weld
Here is a shot of a Model A Tudor that the soft top replacement panel was Panel Bonded in around 2005. Has been street driven since then and still zero flaws at the bonded joint.
[img]https://i.postimg.cc/ZWXrB8Df/IMG-4335.jpg[/img]
Evan
