2 members (klhansen, TUTS 59),
64
Mod | | | Forums66 Topics128,066 Posts1,055,873 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | Hello everybody!
I talked a friend into buying a 1936 ton and a half dump truck for his company parade unit. It's been sitting way to long since, and I'm thinking the fuel pump isn't getting the message that we want to make it run.
The 37's (start of the 216) and forward seem easy to get a rebuilt pump or at least the kit to do it, but 36 (last of the 207's) is seeming pretty tough to find.
Anyone got suggestions or leads on how to either get another pump, or get a kit to do it myself?
Also, the distributor seems loose, anyone have a picture or suggestion on where the distributor should be alligned to get it close enough to run? I see a timing light in the future, but at least a rough timing will be better than having no idea.
Thanks!! | | | | | Joined: May 2015 Posts: 11,048 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,048 | Check with Then and Now. I got a rebuild kit from them and they had quite a few different rebuild kits. Search their site with the part number from your fuel pump.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | Thanks!!
I had stumbled onto the Filling station site at one time, but couldn't remember it or find it again.
I appreciate the help!! | | | | | Joined: May 2019 Posts: 3 'Bolter | | 'Bolter Joined: May 2019 Posts: 3 | I have a 36 Master Town Sedan. It should have the same fuel pump as your 36. There were an assortment of fuel pumps available for that engine. The one that was on my engine when I got it was an after market one and the check valves in it leaked. That pump had press in checks and would have to be sent out for rebuilding. Not many shops have that type of checks for my pump any more. I found an original type replacement from Doyles Carburetor in Georgia but he has since passed away. You might check with Gary Wallace in Missouri. You can also post in the parts wanted section of the VCCA website. You do not have to be a member for that. There is also a section for Trucks on that site that may have more information for an early model such as yours. If you need some other leads for mechanical parts for that engine send me a pm.
Just so you know, 36 was a big transition year for Chevrolet. That is the last year of the 3 main bearing original stove bolt 6. It is also the first year of the full water jacketed engine. So in other words a one year item. It will serve your friend well for MANY years as long as he does not over rev it. | | |
