1 members (carbking), 103 guests, and 8 robots.
Topics128,021
Posts1,055,355
Members48,420
#1425488 09/30/2021 1:50 AM
Hello,
I have a 58 Chevy Apache 3600 with a Napco 4x4 installed. I have noticed that I have oil leaking out of the front steering knuckles. My question is where do I get the seals to replace the ones that are leaking. While I have it apart I would like to replace them all but do I get them from GM for the year and make or do I have to find them from somewhere else.
Thank you for any help.
Rigwelder
They are out there . Any parts store will be able to help with the numbers.
Good luck
CR14866 If you can find them. found mine on Ebay
National #480630 easy to find.
Its a one way seal will let grease in but will keep oil out of axle tube .
Make sure you have the knuckle greased right .
!956 Gmc Napco 4x4 Factory line built .
Good luck
These numbers are for half ton and 3/4 ton
Perfect,
Thank you for your help and I will start looking for the parts and see if I can find them.
