8 members (homer52, tclederman, Gdads51, Mike B, 78buckshot, Sjm, TooMany2count, 52Carl), 95 guests, and 1 robot.
Topics128,263
Posts1,058,333
Members48,485
#1425218 09/26/2021 4:59 PM
Hello, I’ve done some searching but didn’t find any definitive answers. I’m thinking the fenders that came with my truck are bigger (1.5 ton fenders). I tried to bolt them on to do some test fitting but they just seem too big for my 1950 3100. Is there any measurement available that would confirm this? Looking at pictures, the 1/2 ton and 1.5 ton fenders look similar. I’m pretty bummed, these fenders and inner fenders are in great shape. I inherited the truck so there is no previous owner that I could contact. Thank you
1950 Chevy 3100
Jason
1950 3100
50shep #1425237 09/26/2021 9:04 PM
I'll try and remember to get out in my rolling storage shed to make a couple of measurements for you on my fenders. I have a few other things on my plate right now, so it may be a few days.
I suspect you'll find that you have big bolt fenders. Where they bolt to the cab should be identical, but the wheel openings are supposed to be larger for tire clearance.
50shep #1425249 09/26/2021 10:25 PM
No worries. I’m sure you’re right. I guess it’s repos for me. Can anyone tell just by looking at a pic?
1950 Chevy 3100
Jason
1950 3100
50shep #1425259 09/27/2021 12:33 AM
Kind of hard to tell, but I think the "little bolt" fenders have a bit more metal at the front lower part at the wheel opening and also at the rear lower opening.
Here's a photo of my truck fender for comparison.
50shep #1425262 09/27/2021 1:13 AM
Crusing in the Passing Lane
That tan ‘glass fender has a larger wheel cutout, can’t tell if it is 1.5 ton size or not. I would be surprised if anyone wanted to male 1.5 ton fenders?
Ed
50shep #1425264 09/27/2021 1:47 AM
Yeah. I think I just need to accept the bad news. I’ve had this truck for two years, not sure how I’ve just figured this out frown It’s not tan or glass… it’s been sandblasted but now has some surface rust. Money well spent on sandblasting😁. Does anyone want some free 1.5 ton inner and outer fenders??
1950 Chevy 3100
Jason
1950 3100
50shep #1425270 09/27/2021 3:06 AM
Fox Offline
I’m not 100% sure on the big bolt fenders from the photo, but the regular sized fenders have that flat area on the opening arc where the fender brace bolts on. It is apparent in the little trucks, but the big bolts seem, to me at least, to have a better arc without that flat spot near the front.
Those flat spots would be at 10 o’clock on the LH side, and 2 on the RH.
Does this help?
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
50shep #1425286 09/27/2021 3:14 PM
I think I see what you are talking about. There is a flat spot on the inside at those locations for the brace. I keep looking at pics online. I think the giveaway is the front of the fender, its just much thinner near the front than the 1/ ton fenders. When I try to bolt these up the holes to align but the fender comes up higher and the front extends past the radiator support holes.... I think that is the dead giveaway. Thanks all for the help.
1950 Chevy 3100
Jason
1950 3100
