0 members (), 89 guests, and 1 robot.
Topics128,211
Posts1,057,475
Members48,473
I have been wanting to put seat belts in my 4100 since I bought it, but was not coming up with an easy effective way to mount them to the floor, so I simply mounted them to the back of the seat frame with a 51 inch piece of angle iron spanning across the back where the the top, and bottom cushions meet. It keeps the ends of the belts right next to your hips. I know it is not as effective as a 3-point belt, but I figure the seat frame is sturdy enough to at least keep me inside the truck if something bad happened. Plus it will keep the grandkids from sliding across the seat into the door while turning. I used 48 inch lap belts, and will install a center belt after I take the ones out of my 55 Chevy 210 which I temporary installed before I put in 5-point harnesses this winter.
I I lifted my fuel tank and mounted my brackets to the floor between the tank and seat riser. It is much safer then connecting to the seat riser.
Chris
If you're going to use angle iron, put it under the cab floor and drill and bolt Grade 8 3/8" or 7/16" fine thread bolts and big flat washers (3" or so in diameter and 1/4" thick) to pull the angle up against the floor. A bolt around 3" long or so can also be used to attach the seat belt bracket and it will spread the load better than an above-floor angle iron.
Actually I think my method is more than adequate to keep me inside the truck, and held in position to manhandle this truck. Of course then there is the steering wheel, but I like to drive my fire truck like it's on the way to a fire, which is difficult if you can't stay strapped into position. There are many modern cars with belts attached to the seats, and the seat frame in these trucks are probably more over built than most of them.
I can't go over 45 anyway, and a great, safe driver.
An impact at 45 MPH with an 180 lb person strapped in will put ~18,000 lb on the seat belt. The seat frame is mounted with 4 each 5/16" bolts thru 19 gauge sheet metal, so that's the weak point. Your angle iron just moves the failure point to the seat frame mounting bolts. The bolts may hold, but the sheet metal may rip out.
Keep your fingers crossed.
Moderated by  ndkid275, Phak1
