6 members (1955 1 Series, 53again, Cosmo, Hotrod Lincoln, mason86, Gray_Ghost), 100 guests, and 1 robot.
Topics128,068
Posts1,055,883
Members48,428
#1424858 09/22/2021 12:37 AM
I got a radio it is supposed to work, my truck is all taped up ready for paint but I want to bench test the radio. The truck is 12 v so I have a 12 v to 6 v converter 20 amp. My plan is to test the radio using the trucks 12 volt battery and the converter. Seems like it should work. is this correct? also when I plug the antenna in (it is not attached to the truck, just laying on the bench) do I have to ground it or does the antenna cable take care of that ?
sorry for the dumb questions but I don't want to blow up a working radio....
1953 3100
W Online: Content
I used a 6-volt battery charger to run a radio in the basement.. Don't know if that's approved.
2 Offline
You aren’t doing anything fundamentally wrong
Your setup should not cause damage
The antenna doesn’t strictly need ground its specific geometry will only affect efficiency at reception
A quarter wave antenna needs a ground plane to reflect an image so you have a pseudo dipole but when it’s not present stuff still works out okay and you will get many local stations just fine.
Original 6v radio is happy with 5-8 volts and either polarity the radio is good on positive or negative ground because the front end is just a chopper for the power to the ac transformer and it won’t care much at all.
Let us know how it works out
-s
Thanks for the help (and confidence) I set it up the way I described got power and listened to some tunes it sounded great. Best of all the magic smoke is still inside!
1953 3100
