4 members (dt235sd, Wally / Montana, carbking, homer52), 146 guests, and 1 robot.
Topics128,195
Posts1,057,369
Members48,469
Crusing in the Passing Lane
Since factory wheels to fit this GM bolt pattern are getting very difficult to find, I started looking for options. It turns out mid sixties to mid eighties C-50, C-60, LCF and probably others have the 5/10 on 8.750” bolt pattern. The hub diameter is 6.250” vs. 5.250” of the earlier wheels. Upon inspection, there is enough material to support the smaller bolt pattern.
I found several wheels, they come in at least 6”and 6.5” widths. I drilled the smaller bolt pattern using a rotary table, made a spacer to accommodate the hub differences. There clearly is enough material, strength wise.
If one does not have access to a rotary table, one can use a drill press if the throat is deep enough. Make the hub adapter using a face plate and washers so the diameters will be concentric, make or get some drill bushings to fit the diameter of your 20” wheel lug bolt holes, get or make a few pins to lock the wheels together and go for it.
The silver paint in the picture indicate the smaller bolt pattern, only one nut is attached.
Ed
9
9 Offline
Ed are you using the torque plate as well?
Karl j Townsend
No, the studs are too short, just the slotted nuts that came stock on truck.
Ed
