2 members (Joe H, PAUL Berardi),
140
Mod | | | Forums66 Topics128,111 Posts1,056,246 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2019 Posts: 22 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 22 | I have a 39 Chevrolet Master Deluxe car. The orginal engine is a 216 but the block is cracked. So I have 2 other engines I can use. Can anyone tell me the size of both engine and what year? Which one would be better? I will probably will ad a T5 transmission and the rearend. What gears would be for highway 3.50? Thank you for your help.
1 CL9601592 2.06417087F | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Do the 2 other engines have 4-screws around the base of the valve covers, or, do they have 2-bolts through the top of the valve covers? Find and post the codes found in these links: 2 bolt engines4-screw engines | | | | | Joined: Oct 2019 Posts: 131 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 131 | If the crack is on the right side just in front of the petcock you should read the previous discussion about a common crack in that area and the simple fix | | | | | Joined: Oct 2019 Posts: 131 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 131 | | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Numbers are in initial post. Let’s help ID these!
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Like Tim said, we need more info...pictures would also help us help you. Serial number prefix code "CL" and suffix code "F" are not showing up in my search. What are the casting numbers? Mike B  | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Numbers are in initial post. Let’s help ID these! 1. CL9601592 2. 06417087F Maybe those are Engine Serial Numbers? Post the various codes that are found at locations shown in the link given in my post above. They will help ID the size and year (and maybe the application) of the engine - casting codes - casting dates - and maybe designate the use of the engine - car/truck and maybe the size of truck) The casting codes are the most useful codes for IDing an engine. | | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | Depending on the 5th. gear ratio of the T-5, a 3.50 rear axle might be a bit too tall. Something in the 3.70 to 4.0 range might be better. If those engines might have been built in Canada, the serial number charts available for ones made south of the border won't be of much help. Try looking for casting numbers, located down near the oil pan rail just behind the timing cover. A 216 engine that I'm working on currently has the same number as the one behind the distributor stamped into the gasket surface where the pushrod cover fits, near the front of the engine. Jerry
| | | | | Joined: Dec 2019 Posts: 22 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 22 | Thank for your help. I will now what to look for. I love the help I get from this forum. People with more knowledge than I have. | | | | | Joined: Dec 2019 Posts: 22 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 22 | I went back rereading of the post. I misunderstood the location of ID numbers. I will look and give the correct numbers and location I found them in. I apologize for my confusion. I have been sick for awhile. | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | | | | | | Joined: Dec 2019 Posts: 22 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 22 | I hope this helps thank for all you assistance.
I did find the correct on engine block bellow distributor 3764476
Con4 low right side towards the back of the block B240 same as above location 06110878F255C flat space left of the distributor. Top of the 3836848 Con 9 | | | | | Joined: Feb 2019 Posts: 4,482 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,482 | The code 3764476 is a 235 produced from 58 thru 62. The number 3836848 is a head code and that was produced from 56 thru 62. Codes courtesy of a fellow ‘bolter, Deve’s website. http://devestechnet.com/Home/CastingNumbers
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | 06110878F255C flat space left of the distributor. 06110878 = engine serial number starting with 0001001 at each engine plant. F = Flint Engine Plant 255 = Second Series 1955 C = engine type...check this letter, I don't see "C" as a good code letter. Mike B  | | | | | Joined: Dec 2019 Posts: 22 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 22 | I looked at engine type it look like it could be C or B. But I think you maybe the letter B. Thank you so much for all of your help. | | |
