Winter is Coming
A good Tech Tip WINTERIZING YOUR TRUCK including a link back to the Forums for additional tips.
Hopefully this would be the right thread for this. I searched and didn't see what I was looking for... unfortunately one of the previous owners of my vehicle decide instead of cutting out the rusted bumper bolts w/ an acetylene torch that he would cut the frame on the front. I'm trying to find a picture or specs for what they are supposed to look like so I can fab some new bumper mounts. Any help in that direction would be appreciated. I know I could just wing it when the bumper gets here but would rather plan ahead if possible.
My 1960 GMC. Which was sold. Zoom up to see the shape. If I still had it I would measure and make a drawing. This will get you started til others reply.
The simple way to solve the frame issue is to find a '63-66 C-10/20 frame and harvest the bumper ends off then weld them onto your frame. You will have to be careful with the re-attachment because the stock bumper bolts directly to the frame. The easy way to harvest the frame ends would be with a battery powered 'Sawsall'. Wm.
