0 members (),
69
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 28 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 28 | 1952 Chevrolet 3600, transplanted 235 from 54 BelAir. Where does one get Ujoints for this truck?
What would be the best rear end gear/set up to run at a reasonable RPM on the highway. And yes, I would still like to maintain the 8 lug setup.
Any help appreciated. Thank You | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Some of those rigs have a combination of a short torque tube at the transmission, a carrier bearing, and an open driveline between the carrier and the rear end. The enclosed U joint at the front can be scarce and expensive to find. The open joints should be available at any local parts store with a gray-haired oldtimer who knows how to read a paper catalog and use a set of dial calipers. The HO 52 axle has two ratios that are commonly available, "slow" and "really slow"- - -4.56 and 5.14. The 4.10 gearset that was used in the mid-1970's 3/4 tons with an automatic transmission is extremely hard to find. Try looking for a GM 14 bolt corporate axle from the mid-1980's with a better selection of ratios. The ones from a small box truck with single rear wheels will be about the right width for the 3600. Good luck! Jerry
