8 members (walter74, TexasJim50, MarkT, Gdads51, Hotrod Lincoln, Tinker5, MNSmith, 39Master85), 132 guests, and 3 robots.
Topics128,164
Posts1,056,978
Members48,458
#1420104 08/10/2021 5:26 PM
I have read of various means to fix oil leaks on a 235 6 cyl engine, be it cast aluminum cover, new gasket and "ultra black", re-peen the steel valve cover... I have two question; Some cast valve covers state "no baffle," is that a good or bad issue? Secondly, I see "load spreaders" available for V-8s valve covers but none apply to a straight 6, anyone know if they will fit a straight 6? They look like they would. Thanks for your input.
1959 Chevy Apache Stepside Truck
Moderator, Electrical Bay
If you want to use the cast aluminum cover, that's a different discussion and a personal choice. Like other things, there will be pros and cons and you can find those if you search a bit.
If you want to use your stock valve cover, then please go down to a post in this same section from a couple of weeks ago titled something like "Banish Valve Cover Leaks Forever." It should be about 10 or 15 posts down from this one. All you need is a saber saw, a metal blade, a file and some 3/16" aluminum you can cut into pieces from templates you'll make. Then some slightly longer screws (I got them at True Value) and you'll be good to go. You might be able to use the spreaders for the V8 engines, but the best way (if of course you prefer to use your stock valve cover) is to straighten the valve cover out completely, use a new gasket and apply pressure from end to end of the valve cover. Good luck!
~ Jon
Actually the title is "Valve cover leaks banished."
~ Jon
The G.M. ones can be heated & formed a small amount to fit. They do help. I lightly glue the gasket to the head over the 4 studs, install cover, reinforcements & nuts.
BC
1960 C60 pasture art
Thanks for the feedback everyone.
r
added photo.
BC
Load spreaders for Chevy V8's is what you hear about. First load spreaders that I know about were on factory 1963 Chevy Corvair 6 engines. the factory ones are a bit beefier then some aftermarket ones. They would not fit well on a 235 without a good bit of grinding so that they would clear the valve cover lip. BC's picture kind of shows this.
H Online: Content
In the days before hydraulic lifters, valve covers were removed frequently for valve adjustments, and a gasket was not expected to last more than six months or so, maybe a year at most. Two studs on the 216's and early 235's, and four bolts on the later models was not nearly enough clamping points to eliminate all the drips, but most people were not so fastidious as to get a case of the vapors over seep leaks. When a stovebolt quits leaking, sort of like a Detroit Diesel, put some more oil in it- - - -it's empty!
