6 members (MNSmith, Wayne67vert, 55shaker, Hotrod Lincoln, Dusty53, 1 invisible), 154 guests, and 3 robots.
Topics128,090
Posts1,056,369
Members48,442
#1422878 09/03/2021 10:34 PM
'nother newby question. On my 235 motor, theoretically from a 57 belair donor, the return line from the filter canister bolted on the intake is routed around the motor and connected to a fitting in the side of the head on the passenger side. The feed line is coming from a T low on the drivers side. I've seen a few pictures of motors with the same connection but I've also seen return lines routed to a passage not far from the feed port. What gives ? Can I move my return line to the drivers side for a cleaner look ?
That spot on the head was an access point that Chevrolet used to drill a horizontal passage to supply oil to the rocker shafts. It was plugged with a 1/8” pipe plug originally.
If there has been some passage way that has become plugged in the block or before that horizontal path, it was common to run an external line to that spot.
You can try to relocate the return line and see if you still get oil to the rocker.
My Blog
