| | | Forums66 Topics128,043 Posts1,055,610 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 22 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 22 | Hello,
I am having trouble getting the window frame to bolt to the window track/ regulator. The bolt hole do not quite line up. The track portion of the regulator is original to the truck but the window frames are not. When the window rests on the track the threaded bolt holes on the window frame are just a fraction of an inch higher than the slotted holes in the track. Is this a defect in the window frame? Am I missing something.
PS Can anyone share the correct hardware to bolt the windows in place when the issue above is solved?
Thanks | | |
