3 members (2-Ton, Mike B, 1 invisible), 69 guests, and 2 robots.
Topics128,030
Posts1,055,419
Members48,422
#1422270 08/29/2021 3:09 PM
I'm at my wits end. I just tested four new condensers for my 54-3100. I'm down to one, this is nuts! One our fellow bolters makes a capacitor for our old truck guys. I'm down to one, what am I going to do if it goes out on me on a road trip. doc
Doc.Hall #1422275 08/29/2021 3:23 PM
Look at the first post.
Another quality post.
Real Trucks Rattle
Doc.Hall #1422282 08/29/2021 3:50 PM
There are plenty of "new old stock" condensers available on Ebay. Shop for "Delco Remy" (NOT "AC-Delco) Since about the only difference in most condensers is the length of the pigtail, don't limit your search to "Chevy six" items. Back when I was working for a living, feeding my family and paying rent fixing these old rust buckets, failed condensers were incredibly rare, even if they didn't get changed at every tune-up.
Doc.Hall #1422287 08/29/2021 4:08 PM
Moderator, Electrical Bay
Which condensers are you testing? Please contact me via PM or by email ([email protected])
~ Jon
Doc.Hall #1422289 08/29/2021 4:21 PM
Ex Hall Monitor
Ex Hall Monitor
I don't know if I'd be too excited about NOS condensers. I've been told they don't age well in the box.
Doc.Hall #1422321 08/29/2021 8:21 PM
They don't Tiny. The original condensers were made using the foil wrap method. A dielectric gel or film was applied to foil which was cut in strips and then to length and then spun on a machine into a cylinder and this was inserted into an aluminum canister. The ends made the contacts, and that became the capacitor. The ones made by Delco-Remy and Standard were very accurate. The ones made in China are horrible.
The problem 40 to 60 years later is the dielectric gel/film dries out and this causes them to stop working. If they're stored in a hot place, they can be ruined in less than 10 years...and that not surprisingly is why everyone was told to replace them anytime you changed points. The distributor being a hot place by nature.
~ Jon
Doc.Hall #1423156 09/06/2021 8:45 PM
The Delco-Remy condensers from the 1960's and before used an actual piece of paper for an insulator between the foil layers which did not deteriorate nearly as badly as the gel coating that was used in later production. They lasted about three days past forever! About the only way to destroy one was to hit it with secondary voltage that would actually burn holes through the paper insulation.
Doc.Hall #1423254 09/07/2021 7:01 PM
Moparguy, I moved your post to the original condenser thread. Thanks for the info.
Real Trucks Rattle
