1 members (RLB),
215
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Changing from 6 to 12 volt. Have headlights, know the tails. Need numbers for dome, and dash lights. Dash quit working, think I blew them all on 12. I changed the one in ignition swith and that is only one I had. My heater runs on 12, two speeds. How long is switch and motor gonna last? I can get new switch, and motor too, but may run the six, long as it stays running. Changed the coil today, put on an alternator.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | #57 I think, maybe #53 for smaller? the heater motor will last a fair while, but if the switch is the vaiable speed type [or 3spd] it'll fry, sooner if used at low speed - the switches can be got easily at the parts store tho, wait to change the motor til it fries - good job on the alt - it'll save problems down the road!
Bill | | |
