1 members (KEVINSKI),
119
Mod | | | Forums66 Topics128,162 Posts1,056,943 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2019 Posts: 464 'Bolter | | 'Bolter Joined: Nov 2019 Posts: 464 | I have a 2001 5.3 running a 350 turbo transmission. I bought a universal dust cover for a 350 turbo and it just won't fit. The starter is the main issue. I've modified it and if I cut any more metal away to clear the starter there won't be much left to support that side of the cover. The cover still needs to go up further to get the bolts in but the starter is still hitting. I cut away the piece that goes between the engine and transmission as there were bolts on the tranmission that were interfering. Is there a cover out there for sale that will work for my application? I been driving without one for 1 1/2 years and probably don't need one but recently I've been hearing a noise that sounds like maybe a rock or some road debre has been caught in that area and ginding around for a few seconds. I don't hear the noise every time I go out. Just ocationally. | | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | Make a template out of thin cardboard that will fit the contour of the starter, and transfer the shape to a piece of sheet metal. Then pop-rivet that piece to the "universal" dust cover - - - -which obviously isnt universal. If necessary, include a tab to attach the plate to a hole drilled and tapped into the bell housing. Problem solved! Jerry
| | | | | Joined: Nov 2019 Posts: 464 'Bolter | | 'Bolter Joined: Nov 2019 Posts: 464 | Make a template out of thin cardboard that will fit the contour of the starter, and transfer the shape to a piece of sheet metal. Then pop-rivet that piece to the "universal" dust cover - - - -which obviously isnt universal. If necessary, include a tab to attach the plate to a hole drilled and tapped into the bell housing. Problem solved! Jerry Good idea. I've got a pop-rivet gun so ill give it a go. | | | | | Joined: Jul 2019 Posts: 559 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 559 | Yea ive never run one on any of my LS swaps with old 4 speeds, th400’s or the old 319 in my truck. If you want one just make one up out of some thin sheet steel or even aluminum. Cardboard firts and then chop, hammer, bend drill, then enjoy the useless cover that makes you feel better hahaha. | | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | Here in America, we have things called "gravel roads". I drive half a mile from home every day before I encounter the first pavement. Getting a rock wedged between the flywheel ring gear and the bell housing can be an interesting experience, no matter what the sarcastiic city slickers think. Good luck with your project. Jerry
| | | | | Joined: Feb 2020 Posts: 69 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 69 | My truck isn't drivable yet but I start it up once a week. I put my dust cover back on after a cat decided it would be a good idea to take a nap atop the input shaft and clutch. Interesting mess.
Mason
1947 Chevy 3100 -57 Chevy 235 -95 S10 T5 Transmission -97 Blazer 3.42 Rear End
| | | | | Joined: Mar 2007 Posts: 3,438 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,438 | My truck isn't drivable yet but I start it up once a week. I put my dust cover back on after a cat decided it would be a good idea to take a nap atop the input shaft and clutch. Interesting mess. YUCK....
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | Dad got a call early one cold morning from one of his customers, a man who drove a 53 Pontiac straight 8. "It made a screeching noise when I started it, and now the generator light is on". The cat that had been sleeping on the spark plugs of that flathead engine jumped into the fan and knocked the belt off the pulleys. Dad said it looked like an explosion in a meat packing plant under the hood! Jerry
