1 members (Danielbolt), 164 guests, and 3 robots.
Topics128,149
Posts1,056,818
Members48,456
I’m getting ready to reassemble a W-1 carb and noticed there is a slight bend in the metering rod.
Is this normal?
If it is normal does it matter which way it goes on?
I’m pretty sure it’s a 684s because of the flat rod that runs up to the choke if that makes a difference.
BTW it’s going back on a 1940 216.
Thanks for the help
~ Bob Clark, Colorado Springs, CO
1940 Chevy 1/2 Ton
"A 870-Mile Drive. Am I Nuts?"
Carburetion specialist
Dr Goodpliers (the evil twin of Mr. Goodwrench) has been working on your carburetor. wink
The metering rod should be perfectly straight.
Acquire a plastic hammer, and a hard flat surface. Roll the rod on the flat surface, and tap it with the plastic hammer until straight.
Jon.
The Carburetor Shop
Thanks Jon!
That is what I suspected but I wasn't sure and didn't want to go pounding on it until I was.
Thanks Again!
1940 Chevy 1/2 Ton
The first Quadrajet carbs that I went to school on in the mid-1960's had small brass primary metering rods that just hung loosely in the jets. After a few thousand miles they started running rich. We found the metering rods worn undersize, and egg-shaped, oversize holes in the jets, caused by the swirling action of the fuel flushing through them and the rods rattling around. Rochester solved the problem by adding a small tension spring to the metering rod holder that made the rods drag the sides of the holes and stop free-floating.
Actually there is a spring on the W-1 metering rod.
Was kind of wondering what it was for.
Thanks for the info smile
1940 Chevy 1/2 Ton
Got it finished and back on.
1940 Chevy 1/2 Ton
Bob - it looks very nice!
Jerry - Carter started using springs on the metering rods in the 1930's.
Jon.
The Carburetor Shop
Thanks Jon,
When I tried to start it I found out the fuel pump had also given up.🙄
Now it’s apart on the bench waiting for the rebuild kit.
I guess there is always one more thing.
1940 Chevy 1/2 Ton
Fuel pump went back on tonight and I got her started.
No flooding of the rebuilt carb and I was able to tune her by ear and she starts easy!
Thanks again for the advice!
1940 Chevy 1/2 Ton
