0 members (),
79
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,195 Posts1,057,374 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 34 'Bolter | | 'Bolter Joined: Dec 2000 Posts: 34 | I have a 1951 chevy 3100. Is there suppose to be power to both leads on the back of the ammeter with the key off? | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | | | | | | Joined: Feb 2004 Posts: 29,882 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,882 | Yes. The ammeter measures current flow, sort of like the water meter in a household plumbing system, so the "pressure" (voltage) will be the same on both of the terminals. A voltmeter will have battery voltage on one terminal and ground (zero volts) on the other side. Jerry
| | | | | Joined: Dec 2000 Posts: 34 'Bolter | | 'Bolter Joined: Dec 2000 Posts: 34 | Ok, maybe my ammeter is bad, it doesn’t show charge or discharge. The needle doesn’t move. | | | | | Joined: Jul 2000 Posts: 2,207 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,207 | Or someone has messed up the wiring, effectively bypassing the ammeter.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Dec 2000 Posts: 34 'Bolter | | 'Bolter Joined: Dec 2000 Posts: 34 | 12.6 volts at the battery, 14.23 at the battery with the engine running. So must be a bad ammeter. Now would be a good time to convert to a volt meter. | | |
