6 members (Wally / Montana, WICruiser, GMCJammer51, Ole49GMC, 2 invisible), 103 guests, and 1 robot.
Topics128,196
Posts1,057,385
Members48,469
I have a 1951 chevy 3100. Is there suppose to be power to both leads on the back of the ammeter with the key off?
2 Offline
Yes
Yes. The ammeter measures current flow, sort of like the water meter in a household plumbing system, so the "pressure" (voltage) will be the same on both of the terminals. A voltmeter will have battery voltage on one terminal and ground (zero volts) on the other side.
Ok, maybe my ammeter is bad, it doesn’t show charge or discharge. The needle doesn’t move.
Insomniac
Insomniac
Or someone has messed up the wiring, effectively bypassing the ammeter.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
12.6 volts at the battery, 14.23 at the battery with the engine running. So must be a bad ammeter. Now would be a good time to convert to a volt meter.
