| | | Forums66 Topics128,031 Posts1,055,434 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 26 Junior Member | | Junior Member Joined: Jan 2005 Posts: 26 | Well, it's all done. The 216 has been completely rebuilt and is back in the truck. I be excited. But . . . I am having two problems: 1. There is no oil up at the rockers. Before installing the engine I spun the oil pump with an old distributor and drill motor - lots of oil up top at the rockers. Now after peeking under the valve cover there was very little oil. This was after extensive turning over with the starter. What could have changed? The only thing that I added after spinning the oil pump before installing the engine was a bypass oil filter. 2. I cannot get a spark from the coil. I have a new battery and I have checked the wiring a few times. There is good spark at the points. I have verified that the distributor is in correctly - it lines up well with TDC. There are 6 volts at the positive side of the coil and 6 volts at the negative side of the coil. The points are gapped to .018. I have tried changing out the 6 volt coil. I have tried two coils - the original one that worked before I swapped the engine and one coil that is new. I have checked the polarity reversing switch and there are 6 volts at each of the two outer poles with a good ground in the center. What do I do now? I want to say, "thanks" in advance. Thanks! Michael Lubitz (512) 306-1681 '46 3/4 ton stock named, "Buddy" | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | 1) You won't get much oil flow up to the rockers by turning it over. The oil distributor valve will not send any up there until you have full pressure. If you are worried, try the drill routine again.
2) Turn the motor over until the points are open. Put a spark plug wire in the coil tower, attach to a spare spark plug and lay it on the valve cover. Now , with a spare jumper, apply a ground to the coil wire that goes to the points. Do this momentarily several times. You should then see the spark.
The next step is to see the spark while turning the motor over. After that, re-install the coil wire in the tower and look for a spark at one of the spark plug wires with the spare plug. | | | | | Joined: Nov 2004 Posts: 266 Custom Title | | Custom Title Joined: Nov 2004 Posts: 266 | Check to see if you have continuity from the coil tower to the - side of the coil. If you don't, it indicates a bad secondary winding in the coil. It's unlikely that you have 2 bad ones, but it is possible. The fact that the points are sparking indicates that you have a good primary winding in the coil. What do you mean when you say you have 6 volts at the negative side of the coil? How exactly were you checking that?
49 Chevy 3600 65 Chevy K10 48 International KB-1 Service Truck 55 Willys CJ5 - Chevy 331 powered 26 Model T Roadster Rat Rod 70 Tucker Sno-Cat 442-A 96 Dodge 3500 Cummins dually flatbed x-cab 4x4 06 Jeep Wrangler LJ rock crawler If you can't fix it with a hammer, it's an electrical problem | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Try a new condensor. I think the oil will come up when you get it started.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
