I'm guessing vacuum port for wipers. You don't mention year or engine.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
It goes on 250 motor that I have installed in a '56 Chevy. 1956 Chevy's came with a 235 6 cyl. however I was able to fit a 250 in the car without problems.
Just stick a plug in it if you don't need vacuum. It'll run like crap (if at all) if you leave it open.
I think that was the PCV connection, and it possibly had a T that fed into power brake booster. If you know what year the manifold came from, you can look at the GM Heritage documents and probably find the vacuum network. Around 1973 EGR started and it could have been connected with that, also.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
This is a vacuum diagram for the 1971 250 (with 1bbl), and some may be different on yours (depending on year). But I doubt you'll be using all this stuff, at any rate...
