4 members (54farmtruck, klhansen, Bill Hanlon, Otto Skorzeny), 95 guests, and 2 robots.
Topics128,151
Posts1,056,994
Members48,460
What (if anything) would originally have been used to cover the tailgate chain? Without some sort of cover, seems like the chain's pendulum movement would scratch the paint on the body. Currently using a section from a bike innertube but would like to find out what the factory would have originally used.
Curmudgeon
Curmudgeon
I believe it was canvas. Canvas will rot and 50+ years later there is no evidence left.
Rubber and plastic need a hole at the bottom of the loop to let the water out.
Bike innertube is what I use.
Canvas...I never thought of that but it makes sense. Now that you mention canvas I can recall lots of similar uses for canvas on military vehicles to provide some protection for or from moving parts exposed to the elements.
I just had my "as seen on TV" expanding garden hose blow out on me. It is a soft rubber hose protected by a loose woven nylon cover. Now that the hose is ruined I may salvage the nylon cover to use on my chains. I'm happy to send you some if you want to try it out on yours.
Mike
I see you have a trailer hitch on your truck. Could you post a picture of how it's made and attached. You said it's a 37 and that's what I have and have been thinking about building one
Thanks, Bill
1937 GC
Curmudgeon
Curmudgeon
I remember seeing worn canvas covers and the chain scratching the paint.
I guess after time the truck got old. Fast forward in time, we are fixing today what was neglected back then.
Thanks but my wife and I ride bicycles for exercise. Changing out worn tires includes new tubes. I have enough old tubes to last me. Thanks again.
Bill,
Trailer hitch pics attached. The PO who restored the vehicle built and attached it. Looks like he built it from scratch. It is welded directly to the chassis cross member just forward of the rear bumper. Happy to send more detailed pics if you need. I probably should have PM'd you but couldn't figure out how to attach photos that way.
Mike
P.S. Interesting story on that trailer hitch; I probably wouldn't even own my '37 if it weren't for that hitch.
I was getting ready to be reassigned from the Pentagon to Fort Hood, TX, so I went to search Craigslist to find a used trailer to move some things myself. I typed "trailer" into Craigslist's search box and, because the truck had trailer hitch, the truck popped up. I had always wanted a '37, but I figured it was for when I was retired/much older, etc. and truth be told, I probably would have never gotten around to it before I died. But the truck was only an hour away, was in good drivable condition, and the price was great, so I talked to my wife and she agreed that since I'd been such a cheapskate on myself our entire marriage, that she wouldn't object. The next morning she had second thoughts, but I told her, "Sorry Honey, I've already arranged to meet the guy today." Needless to say, I've had a bad-[censored] '37 Chevy truck for the last 11 years now and I love it.
This same subject was discussed on the VCCA chat site. I bought some rubber tubing from Jim Carter years ago and it works ok but I am going to go to an Upholstery shop to see about getting some canvas ones made.
1936 GMC T-14 1/2-Ton Pickup
I used some hydraulic hose cloth sleeve covering that I rubbed into the concrete floor under my foot and roughed up and faded the color some so they look like they are aged correctly with the patina of the rest of the truck. Im happy with them.
Take a look at the sleeves they use for covering hydrolic hoses they look like they would work and last forever...
1951/54
Basketcase
Mike,
The hitch looks good. That should certainly come in handy.
On another subject, I see that you have a nice restored 1937 Texas plate on the truck. However, in the picture it appears to be white on black. The plate should have been done as ivory on black. If interested, you can go to this site to research the history of Texas plates...
http://www.thebolthole.com/texas.html
Regards,
Hurst
Hurst,
Actually it is ivory on black, I guess the pics lost some fidelity.I researched it very thoroughly beore i restored them because i was afraid an uninformed clerk at the dmv would summarily disapprove them, so I had the specs and the regs all printed up ready to defend my application. But I forgot how friendly most small town folks are and the clerk just said "Ooh, how pretty!" when she saw the plates and promptly processed my paperwork.
I've attached a new pic with a white board at the top to try to highlight the ivory of the letters.
Yes, that pic looks much closer to ivory. I just noticed the color since I have had quite a few restored . I only use the year plate on the front because I get the antique plate from the DMV for the rear so I don't have to get it inspected.
If you ever want to have one restored, I recommend this guy in TN as he does immaculate work, just takes a long time...
https://www.finishyourplates.com/
Regards,
Hurst
ArmyMike In the late sixties I think they had some rubber ones with a drain hole that with use would break in two and just be a mess on your chain but it did help the paint some. On my homemade bed made some flat iron ones that hide in the crack. Those work great!!
' Offline
My '37 has what I believe are the original covers. They appear to be some kind of light canvas.
Can you send pic of them?
' Offline
next time I go by that garage I'll get pic. Next day or two
' Offline
Currently have 3/4 inch heater hose on original 1954 3100. put a slice on the bottom and drains fine. For those looking for extreme stock replacement check with the good vendors. Doc
