2 members (NJC, baldeagle), 60 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#1417464 07/20/2021 12:56 PM
Was visiting my nephew TJ in New York last week. He had new in boxes McGurdy speed components for 235/261 stovebolts. It consisted of camshaft, roller lifters, push rods, distributor and electrical components. How effective and practical was this set up?
Rick
1939 Chevrolet Stake Truck
rickmg #1417467 07/20/2021 1:03 PM
rickmg You''ll cause a riot mentioning roller cam for a stovebolt,us old geezers liable to soak our depends LOL
rickmg #1417483 07/20/2021 2:53 PM
Never heard of "McGurdy"- - - - -might that name actually be "McGurk"? That company built race parts for stovebolts back in the Dark Ages, and I'll bet that roller cam will be totally unsuitable for anything other than wide open competition at RPM ranges a street engine will seldom, if ever achieve. I'm in the process of adapting a stovebolt engine to run roller lifters on a Corvette/261 cam- - - - -no idea yet if it will work at all, or if it will provide any kind of performance improvement!
rickmg #1417496 07/20/2021 5:28 PM
It was probably McGurk, my error. It had instructions and performance data included. My stock 1939 216 runs just fine!
Rick
rickmg #1417639 07/21/2021 5:32 PM
There is a number on the end of the cam identifying the manufacturer, application, and grind?
No number: reground stock cam.
rickmg #1417649 07/21/2021 8:05 PM
Hey, I ran a McGurk in my 235 from 1966 thru 1969, am I that old? Run high 16"s in 1/4 mile, fitted in my 53 Chevy 2 dr. hdtp 456 rear end, factory 54 corvette ex. man., 383 valve springs plus other mods. Jumped many new cars off the line
rickmg #1417735 07/22/2021 1:39 PM
rickmg That mcgurk stuff would be interesting to look at,I suppose you could get a milder regrind on that cam. A big limiting factor on stovebolts was only 4 main bearings. however we had a hot one on 1/4 mile oval in about 54,but they couldn't hold the driveshaft,suspect engineering there.
rickmg #1417781 07/22/2021 8:42 PM
Reducing duration and lift is ordinary business.
What is pretty much permanent (only very small changes possible) is LSA.
Depending on whether the flanks are convex or not (both were used) it may have enough material to regrind for a flat tappet. If "hollow ground" I would guess not.
The roller tappets should have a link distance around 2" + some wiggle, may have been adapted from GMC (same tappet diameter, different tappet spacing).
Buick L8 also?
Common auto tappets were probably adapted by bushing the tappet bore down to .904" (Chrysler, AMC), .875" (Ford), .842" (GM). More about this on my page here:
http://www.victorylibrary.com/mopar/roller-adapt.htm
rickmg #1417787 07/22/2021 9:43 PM
Unless something is done about the siamesed ports and terrible intake design it's wasted money. As a low rpm torque engine a Stovebolt excelled but no matter how heavy you smear lipstick on a pig it's still a pig in the performance theater. On an overHEAD valve engine the HEAD is everything and all the short block has to do is stay together. If one has to use an I6 then consider the Atlas to keep it all Chevy or a 300 Ford for all American. Lots of foreign I6's to choose from but if serious performance is the goal then seven main bearings and a 12 port head is the base foundation.
Evan
rickmg #1417800 07/22/2021 11:11 PM
There's always the AMC/Jeep inline six, the one that's based on the International truck 232 and 258 cubic inch engine from back in the 1960's. The Jeep 4.0 liter six is a descendant of that design. 12 ports, and a pretty good port design and breathing capabilities. Just paint a bowtie on the valve cover!
rickmg #1417806 07/23/2021 12:47 AM
It's not wasted unless the builder has no awareness of the relatively modest returns per dollar spent.
It's a hobby, not a race. We did the same thing to VW Type I, remember?
rickmg #1417901 07/23/2021 8:08 PM
A McGurk roller cam and roller lifters, soaking our depends, lol, you bet your bippy. I have only ever seen 235/261 roller lifters in photos. Never a real set. Chet Herbert made them for the chevy 6 and Frank McGurk sold parts under the McGurk name that were actually made by another manufacture. It would not surprise me at all to find that those lifters were really an uber rare set of Herbert roller lifters.
How cool! Any chance you would be willing to post some photos? It would be quite a treat to see those old time hot rod parts!
Mike
rickmg #1417907 07/23/2021 8:41 PM
Also used in the day: Harley-Davidson roller tappets (1929-83), which guide the .375" roller in a slot in the tappet bore; no links needed.
.731" body OD, .855" roller.
[img]https://cdn.shopify.com/s/files/1/2505/6516/products/10-0770_750x.jpg?v=1542127856[/img]
rickmg #1417908 07/23/2021 8:42 PM
coilover #1418894 07/31/2021 4:52 PM
coilover Could turbo it, had one turboed once ran fine,lotta plumbingthough ! Its a way to overcome the poor in take system.
