5 members (klhansen, 52Carl, 55shaker, Shardean, Ponchogl), 87 guests, and 3 robots.
Topics128,022
Posts1,055,352
Members48,420
#14171 08/16/2003 7:22 AM
In 1962 there were two 235 engine options. The first one is a high torque 235, and the second one is a high torque 235 w/ maximum economy option carburator.
I've got a Rochester 1 barrel on my 235, with the fuel line facing towards the valve cover. But in the '62 shop manual, it says I should have a BC, or Carter downdraft carb.
All of the other 1962 chevy trucks i've seen with 235's had the carters. :confused:
Can anyone shed some light on this?
TIA,
David
My truck don't leak oil, it just marks its teritory.
#14172 08/16/2003 11:29 AM
k10 Offline
"Fuel and exhaust components remain essentially the same as in 1961 except hand throttle controls and the exhaust system for the new 409 cubic inch Workmaster engine.
Hand throttle controls have been eliminated on 1962 trucks and will be an optional accessory. The 409 cubic inch engine (RPO 421) is equipped with a dual exhaust system."
Taken from ST-9
1960-61-62 Chevrolet Truck Shop Manual Supplement.
Actually, the "BC" you describe is the Rochester B model one barrel carb and if you review your book, you'll see reference to the Carter UPDRAFT carb-not down draft. grin
#14173 08/18/2003 6:50 PM
Yep, "BC" stands for Rochester "B" with integrated choke thermostat. BV is Rochester B with divorce mounted choke thermostat, and plain old B is with manual choke. I run a BC on my 261, works fine.
Paint & Body Shop moderator
