"Fuel and exhaust components remain essentially the same as in 1961 except hand throttle controls and the exhaust system for the new 409 cubic inch Workmaster engine.
Hand throttle controls have been eliminated on 1962 trucks and will be an optional accessory. The 409 cubic inch engine (RPO 421) is equipped with a dual exhaust system."
Taken from ST-9
1960-61-62 Chevrolet Truck Shop Manual Supplement.
Actually, the "BC" you describe is the Rochester B model one barrel carb and if you review your book, you'll see reference to the Carter UPDRAFT carb-not down draft.
