7 members (Lightholder's Dad, Otto Skorzeny, KEVINSKI, lumbersawyer, BC59, tclederman, 1 invisible), 67 guests, and 1 robot.
Topics128,154
Posts1,056,853
Members48,456
2 Offline
My cab took a pretty hard hit on the back roof area at the rear window. I was wondering what the best way to fix this.
Hammer & Dolly and lots of time
Mason
1947 Chevy 3100
-57 Chevy 235
-95 S10 T5 Transmission
-97 Blazer 3.42 Rear End
AD Addict & Tinkerer
I believe that dent is partially hidden by the inner roof panel. A stud welder and slide hammer would be your best bet, but you may be able to pry from the inside with a flat bar (while tapping down the high spots), with the end ground smooth so you don’t leave dimples.
Phil
Project Journals
Stovebolt Gallery Forum
The HB stud welder works well enough and is cheap.
Sir Searchalot
Sir Searchalot
I don't know what HB is? HF?
Anyway the "best way" is the way YOU can do it. If it has access on the inside, it's a no brainer. If not, I could not pull it out without being able to dolly it back down because you can't pull it to original shape. At least I could not. It would have highs and maybe lows after pulling. You can't get rid of the highs unless you have a lot of experience and tools. I think the idea is to pull it almost back up and then fill. Don't create any protrusion.
I would have to cut the piece out, shape it and weld it back on. Been there, done that. Works for me.
Yes, HF. Fatfingered.
