0 members (),
102
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2020 Posts: 74 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 74 | Hope ok to ask here about books. I was wondering if the "Chevrolet Truck Shop Manual 1954 Models" would be the same book for the 1954 GMC 152 Truck? Mainly need something as a reference point in working on my truck/engine.
Unless someone has some pointers to where to go, etc.
The current engine in the truck is a 235. I do have the original 248 engine I'd like to put back in the truck if the block/head is any good, etc...
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | RP14 An old timer gave me an original 54 shop manuel kinda oily you know. Those are good reading,went to roll-in a set of main bearings in my 235. Read all the books-have already done it years ago- Chilton,Motors,Chevy, all different insructions how to do it,so used my method, it's running good today roda and mains all -.002. So read the books do stuff your way !!! Hint--- learn from the old guys !!! | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | RP14 I see your from N. Dakota so you know what cold is,I have recieved some phlack for using 5w30 oil in my 235 51 6400 tractor daily driver. It's my cruiser and burns straight proopane is 98 inch wheel base shortest they built. What oil do you use in N.D.?? | | | | | Joined: Sep 2013 Posts: 1,367 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,367 | RP14, no help on the book question just wanted to say Hello. I spent 2011 thru part of 2014 in ND. Watford City was my home away from home. Lots of memories and good times made there and in the area. Spent a lot of time in the Little Missouri Badlands all the way down to Killdeer. Sadly I was a regular at Outlaws  Hope all's well in my adopted home town. Things should be coming back to life with well completions picking up (according to what I read). RonR
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | Try pulling up the web site "Better World Books". I have been a member for years it has a huge amount of books. We are a non-profit and it cost nothing to join. Doc.
| | | | | Joined: Sep 2020 Posts: 74 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 74 | Always learn from others. Just a ton of books out there and rather spend the money on parts than books. Want to find the books that would be most helpful and of course these forums. | | | | | Joined: Sep 2020 Posts: 74 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 74 | Fixite7, Glad to hear from others whom are from ND. I am just going to use the truck for summer short drives, getting ready to tear down to the frame and restore.
Moparguy, As for Watford City, it's grown quite a bit and a huge change from when you were last here. It's my permanent home, love it here.
Just looking for maybe a couple books to help guide and/or parts, etc. Saw a site classicparts.com they have several books. I have a GMC 152-24 truck and wasn't sure if the assembly/parts were the same as they have different looks. I also want to find a wiring diagram for the GMC, I'm only able to find Chevy wiring diagrams which is different. Going to replace the entire wiring harness and electrical. Might keep it 6 volts unless someone says better to change to 12 volt. I'd like to keep as original as possible.
Open to any suggestions and will be taking notes, etc. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | RP 14 The simplicity of an alternator is what I go for,same with HEI ,same with propane equipment! All are easy to trouble-shoot ! Carry a few parts with you on the road,some tools,go for it. I want to cruise not trouble shoot antique's and fight vapor lock !! | | |
