3 members (Steelonsteel, Hotrod Lincoln, UtahYork), 72 guests, and 3 robots.
Topics128,261
Posts1,058,341
Members48,485
Page 9 of 10 1 2 … 7 8 9 10
THat is a lot of smoke so pulling a lot of oil from somewhere. Does the engine have a PCV system in place? If so did something get disconnected or connected differently that would result in the crankcase being tied into the intake system? Given that it was not smoking originally (if I recall correctly) it is probably something simple rather than the engine being worn out.
I agree with Otto about a leakdown test but with that much oil being sucked into the cylinders spark plug condition will help sort out if its one or all of the cylinders.
1949/50 3600 Project
Follow in Project Journals
I just looked at one of your earlier posts and see that #5 plug was wet with oil. Start with that one with all of your tests.
1950 Chevrolet 3100 (Ol' Roy)
I'll do those tests. #5 cylinder was soaked with oil when I looked. Frankly, it seemed like an abnormal amount of oil, meaning a lot! The engine is not using a PCV system, it still has the road draft tube. I had thought about driving it, again, and trying some hard pulls on the small hill by my house. Is this a bad idea? I won't have an opportunity until Sunday, so there's time to talk me down from the ledge.....
Mike
1953 3100
The Gray Ghost
My Project journal
Not going to hurt anything. The damage is already done. If it's a broken oil ring or worn valve guides, you aren't going to break the rings any worse or wear out the valve guides more than they are by driving up a hill.
It sounds like the engine will need a rebuild or replacement. The engine has always been the unknown, given its junkyard provenance. Sadly, I don't have the funds for either option. This adventure has always been on a shoestring budget. Bummer! I'll have to make a post in the items wanted page here and see if a serviceable engine is out there.
Mike
1953 3100
The Gray Ghost
My Project journal
Or just keep driving it as-is and clean the spark plugs more often. No law against driving a vehicle that burns oil.
AD Addict & Tinkerer
My buddy in high school got a ticket for “air pollution” for his 57 Chevy smoking too much!
Phil
Project Journals
Stovebolt Gallery Forum
Driving it some will not create any more problems than you already have.
I suggest pulling the plugs again and see how they compare to each other and your memory from previous observations. If #5 is oil fouled again and the rest look okay doing a leak down test may help determine if the problem is with the piston rings (valve guide issues will not be obvious).
I do not recall if you have previously determined the origin of the engine (year and any rebuild information). The engine I pulled from mine had a rebuild tag that identified the rebuild information such as bearing sizes etc. as well as its origin being from a car (do not recall the year off hand).
Here's a quick data dump on the engine: it came from the junkyard (pic attached of it the way that I found it). The engine was sitting in a 1961 Chevy Impala. The serial number supports that model year of car. It is a car engine with hydraulic lifters. I do not know if the engine was the original engine for that car or if it was a replacement. There was no rebuild tag attached to it, nor did I notice any remnants of a tag. I have not been inside the engine in any way, so I really have no idea if it has been rebuilt, hacked or modified in any way. It's a mystery, unfortunately.
I will start with a compression test of each cylinder. While I do that, I'll take a pic of each plug. My thought is that if the compression numbers seem roughly equal (they did the original time that I did the test a couple of years ago), then I'm thinking it is valve guide or seal related, instead of ring related. Is that a valid way to think?
After that, I'll regroup and go from there. I'll plan to continue to drive it in the neighborhood, unless something shows up in the compression test. In a less emotional way than my last post, let me say that I have no problem doing (learning) engine work. My issue is strictly financial. I just don't have the money to do any machine shop work. If it turns out that there is some work that I could do, without the need to send it off to a machine shop, then I'd be amenable to that. As it stands right now, I have no confidence that the engine won't strand me on the side of the road.... It really stinks that I've come this far and still can't drive it out in town.
Mike
1953 3100
The Gray Ghost
My Project journal
A compression test is okay but a leakdown test is more informative. A comparison of the current compression numbers to your historical readings can be informative or at least help identify if something has changed.
The group will be able to help identify the original information about your engine with the numbers you should be able to find (some cast in and some stamped) but you will prbably get more response if you start a thread in the engine sub-forum with your information and a request to help identify the engine.
If the only problem that you have is smoking I doubt that the engine will strand you.
Spark plug pics in order #1 - #6. Both #5 and #6 were saturated in oil. #1 - #4 had that tan color to them and appeared to be burning off the carbon from running too rich.
My compression gauge needs a new hose...so that didn't get done yet.
Mike
1953 3100
The Gray Ghost
My Project journal
Well, you already know the problem is with 5 and 6 cylinders. No need for a compression test. Perform the leakdown test on 5 and 6 to see if the piston rings are the culprit.
I'll try to get it done tomorrow.
Mike
1953 3100
The Gray Ghost
My Project journal
Hey Everybody,
Leak down test completed. Results (assuming that I did everything correctly) are pretty clear. First, the setup: I removed all 6 plugs, disconnected the coil wire and installed the fixture that I had previously made per HRL's instructions (thank you, again, HRL). I only bothered with cylinders 5 and 6, since they had the abnormal looking plugs. I rotated the engine by both rotating the fan/water pump and bumping the starter. I aimed for having the pushrod ends of the rockers as even as possible and verified that there was no pressure on the rods. I assumed that with no pressure on the rods, the valve springs on the other end were exerting maximum force on the valves and they should have been closed. It was the only way that I could figure to have the valves closed for this test. If I was wring, someone please let me know. So, I started with #5. Got it to where I thought the valves were closed, threaded in the fixture to the spark plug hole, attached the air hose with 90 psi and nearly messed my britches when the air came shooting out the spark plug hole for #3 cylinder and right at me! Um, yeah, I had no idea that was even a possibility! After collecting myself, I did it again. Same result, minus being startled. Weird. So, off to #6. Here is the video of the #6 test. I'll let the video speak for itself. Now, having a large amount of self doubt, I rotated the engine to see if I would get different results. #5 still shot air out of a spark plug hole, however, the cylinder changed from #3 to a different cylinder (I don't remember which one....). #6 provided the same result as the video, a strong flow out of the exhaust pipe. I rotated the engine a third time. Same results. So, I have repeatable results. Of course, if my test setup is wrong, then I've just repeated the error and the results are invalid. I have an opinion on what part(s) are not working correctly/are damaged. To me, the head is damaged and/or malfunctioning or both. I would like some opinions of the test setup, the logic for the setup, the results and my conclusions, please.
Mike
1953 3100
The Gray Ghost
My Project journal
I am not sure about your setup but if you are getting significant air out of a different cylinder (youtr #5 results) it seems likely that the air is going past the piston into the crankcase and then coming out the most convenient cylinder. Your results for cyldiner #6 would indicate the exhaust valve wasn't seated or is leaking a lot but that doesn't really fit your exhaust smoke and oil fouled spark plug. I suspect your setup is off but your general description of positioning the engine such that both valves are closed should be correct.
I'm sure someone else will give you a better answer.
Getting air out of #3 spark plug when you pressurize #5 seems impossible, unless #5 intake valve is leaking real bad and #3 intake valve is open at the same time that #5 is at TDC compression. That might let air into the intake manifold, up to a closed throttle and back down the intake manifold to the other cylinder. As far as air leaking out past the piston and back up through another piston wouldn't be possible unless the crankcase breather tube is completely plugged.
I agree that if you position the cylinder so both pushrods can be turned would pretty much confirm that both valve on that cylinder are closed, which is the way you should be testing.
The way the crank throws are arranged, #1 and #6 are both at TDC, one on compression and the other on exhaust/intake (with both valves possibly open at the same time). Cylinders #2 and #5 are paired, as are Cylinders #3 and #4.
Originally Posted by klhansen
I agree that if you position the cylinder so both pushrods can be turned would pretty much confirm that both valve on that cylinder are closed.
Unless one of the valves is stuck open.
I guess my question is whether or not there is actionable information from what I did? If so, what would the next steps be? If not, do I need to repeat the test and if so, what should I do differently or in addition to? I'm wondering if it's time to pull the head...?
Mike
1953 3100
The Gray Ghost
My Project journal
True dang
To confirm you're at TDC on either #1 or #6 cylinder, the timing pointer by the starter should line up with the TDC mark on the flywheel.
On Bill's comment, if a valve is stuck open, there would likely be a LOT of clearance between the valve stem and rocker.
I would try and repeat the test trying as best you can to ensure that the cylinder being tested is at TDC on the compression stroke (both valve closed). It may not be easy to confirm if you are on compression stroke but if you place the timing pointer to TDC and check both cylinder #1 and #6 to see if you can tell the difference in the valve/push rod it may help you know what the rockers/push rods should be like on #5.
If you get frustrated enough or just need to know what's going on inside pulling the head is a reasonable step although not free as you will need to replace several gaskets at a minimum.
I'll probably do it again and pay particular attention to the push rods. I'm reasonably confident that the valves were both closed, but I'll do my best to verify it this time. If the results are similar, I'll move on to head removal, even though that will be a large task.
Side note: I still have the derelict engine that came in the truck. It has the same 848 head as the current engine. I've considered swapping heads to see if it'll run. The reason that engine was no good was water got into it somehow and rusted the lifters. I don't remember anything wrong with the head, but the water had to come from somewhere.... Just a thought for 2am.
Mike
1953 3100
The Gray Ghost
My Project journal
Ad posted in parts wanted....
Mike
1953 3100
The Gray Ghost
My Project journal
Water in the back lifters maybe from the cowl vent drain ,may be worth a look at that engine to see if it can be salvaged .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
How bad is the corrosion on the original engine lifters? Are there other areas that are rusted/stuck that make it too much to try and salvage?
Here is a pic of #5 and #6 lifters and push rods in the gallery of the derelict engine. This is why I pulled the engine and labeled it as a derelict engine.
Second pic is of the rockers. I can't find any evidence of water intrusion here. This is why I was considering swapping this head to the engine that's currently in the truck. First thing I noticed is the crimped off pipe in the derelict engine (pic 3). That pipe is not present in the engine that's in the truck. The derelict engine is from 1954 and the truck engine is from 1961.
Mike
1953 3100
The Gray Ghost
My Project journal
Those last two lifters are downhill from the oil drain hole to the pan, so any water that might get in will settle around them. I had some rust around the same lifters on my engine (still operating) but cleaned it off when I went thru it. That pinched off oil return tubing was pretty common. It made all the oil that got up to the rockers go to them rather than just depending on gravity (just the hydraulic head from the high point of that tube.) It's not an issue.
And if you can free up those lifters, it may still be a runner.
Since you have the engine out put it on a stand and take the oil pan off to take a look inside those lifters don’t look too bad and should clean up .the crimped rocker tube may indicate some issue but check to see if they are the correct rockers for the early engine I remember there being a center oil grove and a offset oil grove on the rocker depending on the year of engine.The 54 engine had a slit in the valve cover right below the vent drain so that is we’re the water most likely came from.
"The Journey"
Follow in the DITY
You could try rotating the engine crankshaft slowly while watching the rusted lifters to see if they move. If the are not stuck you should be able to clean them up and determine what, if anything else is a concern as suggested by Kevinski. If they are stuck you will need to decide how much effort you want to put into getting them free to move but I wouldn't condem the engine based on what you have found so far.
Hey Everybody,
Well, I'm very surprised! Those last 2 lifters are crunchy! I will, however, do as suggested! I think I'll give them a really good soak in penetrating oil before trying to rotate the engine. I'm assuming that I'll have to remove the rocker arm assembly to get the lifters and push rods out for inspection/cleaning vice whole head removal. Is that right? Please let me know if there are any things to avoid or specific things to do so I don't make things worse.... Nothing is too basic and I won't be offended by any advice! I'm learning this as I go!
Mike
1953 3100
The Gray Ghost
My Project journal
Hey Everybody,
Lifters and push rod inspection report (pics attached). I only removed #6 cylinder components since that was the most rusted. Exhaust lifter and pushrod are damaged beyond repair and would need to be replaced. Intake is bad, possibly salvageable. Exhaust lifter had cupping on the bottom and a scored ring, intake did not. The engine was stuck, but I managed to free it after some effort. However, there is still a point where it sticks, so I'm assuming there is a rust ring in a cylinder where it sat and collected water. I'm not sure this old engine is worth the effort to save, as it sits right now. Last pic shows the rocker arms. I found it curious that some were adjusted to the maximum in and some barely at all. I don't know if that is indicative of a problem or an adjustment that was only partially completed. No idea. What say you all?
Mike
1953 3100
The Gray Ghost
My Project journal
That’s great you got it unstuck .the lifters that are rusted can be replaced and from the pictures it looks like the block is not rusty were the lifters were. Worth some more checking and maybe worth it to see if it will run.
"The Journey"
Follow in the DITY
In checking online for lifters, it makes a difference if the engine was originally a powerglide engine or not. Based on the stamped serial number (TI28A), this engine was originally for a manual transmission car. The "A" suffix lead me to think this. The lifters appear to be hydraulic lifters, not the milk can mechanical style. Of the 2 lifters that I removed from cylinder #6, I at first thought that one was rusted to the point of disintegrating the keeper wire and allowing the lifter to open to its fullest potential. Now I'm thinking that they are actually 2 different lifters. I'll repost that pic for you all to see what I'm talking about. Back to the serial number. If this was originally a manual transmission engine, why are there hydraulic lifters in it and did the cam get changed with the lifters? Did this engine ever run with this setup? Would it run with a mismatch of cam and lifters? Am I over thinking this? To get this engine to run, I'll have to retrieve and reattach EVERYTHING! Most things I have, but some items would have to be moved from the truck engine to this one. Some items would need to be purchased. Just to see if it runs. Things that make you go, "hmm."
Edit: I've added a pic of the cast date on the block. It is "A2457". So, the block was cast January 24, 1957 and turned into a car engine with a manual transmission on January 28, 1957.
Last edited by Gray_Ghost; 09/30/2026 7:15 PM. Reason: Added information and a pic.
Mike
1953 3100
The Gray Ghost
My Project journal
Looks like those are hydraulic lifters I can see were the clip is to hold the lifter part’s together.You would have to find a few hydraulic lifters and push rods for the engine,as well as check the other lifters and engine components .I put a red line were it looks like the lifter clip is to hold the inners together .
"The Journey"
Follow in the DITY
That would explain a little more the rockers that were tightened down more than the others to quiet the lifters down that were not pumped up as well as the others.
"The Journey"
Follow in the DITY
Mike - I am in the process of getting a 261 rebuilt and ran across a no longer usable cam and original style "milk can" solid lifters. Both worn super bad and even pitted to the point they weren't likely to be salvaged without a lot of $$$ thrown at them.
Anyhow, I purchased a new CSS-1 Cam and then struggled to find new solid lifter to go with the cam. In my searching, I found that the guys at 12bolt.com offered new "solid" lifters" so went ahead and ordered them. Much to my surprise when opening the box, I found what looked like short "hydraulic" style looking lifters, so called Tom at 12bolt. Turns out these lifters, even though they look like hydraulic, are in fact solid style lifters and will work for our truck engines just fine. They do require the use of longer 12-1/4" push rods (in my application) to make up the height difference when switching from the original milk can lifters. But that shouldn't affect your engine as it looks to have similar lifters (likely an early replacement style solid lifter) and the correct length push rods.
Below are some pictures of the new "solid" lifters from 12bolt.com and a comparison shot of the old vs new lifters and push rods to show the height compensation by the longer push rods.
Hope this might be of some help.
PS - If you push down on the center of the existing lifter, if it's hydraulic it will slowly collapse down inside itself. If it doesn't collapse, it's a solid lifter. You might try it with one of the other lifters that isn't all corroded up to do this test. Also look for a "oil filler/bleed hole" in the side of the lifter recess channel. If no filler/bleed hole, not hydraulic. wink
~ Dan
1951 Chevy 3 window 3100
Hey Everybody,
I went looking inside #5 and #6 cylinders with a borescope camera. Pics attached. To me, I found nothing shocking. It looks like some wear marks on the cylinder walls and some potential pitting. One pic shows what looks like a pin hole in the cylinder wall (it's a bit difficult to see, but it is circular). These pics are from the currently installed engine. Does anyone see something worth a further look?
Mike
1953 3100
The Gray Ghost
My Project journal
As I recall the problem was cylinders 5 and 6 had very oily spark plugs leading to the conclusion that the oil smoke was coming from those cylinders. It is pretty hard to determine bore condition with a scope (at least I have not been able to) and impossible to determine if you have stuck or broken piston rings. I know it isn't free but you can pull the cylinder head (new gasket required) and get a better look at things although unless you remove the pistons you cannot look at the rings. You can rebuild the engine without machine shop work if you find that the problem is stuck or broken rings although it will not be as good as a complete machined and rebuilt engine.
Did you repeat the leak down test you reported on earlier? I recall there were some questions about the process and results of the earlier test.
Do you know anything about the history of the engine other than it was removed at a salvage yard? It seems likely that the engine sat for a long time and rings can get stuck. I know there are treatments for stuck rings that may free them up without tearing things apart but I do not have any personal experience or recommendations.
WIC, I did do the 2nd leakdown test. Or, at least I tried. Basically, air shot up through the carburetor. I'm pretty sure something there got damaged as a result. When I tried to run the engine after the 2nd test it smoked a million times worse and ran like crap. It was all very disheartening. I've considered using the Berryman cleaner to see if a ring would loosen up. My concern with that is the sludge in the oil pan. I don't want to dissolve enough of that to clog up oil passages. I've considered removing the cylinder head, but that will require draining oil and coolant. Basically, I'm encountering inertia, due to the amount of work and risk each option carries. That is why I was looking for a running engine to just drop in. Not sure which way to turn at this point, so I've been doing fall lawn and garden tasks instead....
Mike
1953 3100
The Gray Ghost
My Project journal
GG, here's what I would do.
Run the engine to operating temperature and drain the oil and replace the filter.
Remove the oil pan and clean out any sludge you find there and reinstall it.
Then use HRL's engine flushing method to remove all the crud.
Refill the crankase with the cheapest oil you can buy and fill the oil filter canister as well. Add 2 quarts of diesel fuel to the crankase.
Start the engine and run it for 30 minutes at 1500-2000 rpm. Do not drive the truck - just let it sit there.
Drain the oil and diesel mix and replace the oil filter.
Fill with the quality oil you normally run in your truck. It will either smoke or not. After this you can decide whether to pull the head and make repairs to the valve guides
Hey Everybody,
New information! Attached are a pic from #1 and #2 cylinders. Apparently, both pistons have a piece missing and some level of scoring on the cylinder wall as a result! Now I'm wondering if the engine block itself is salvageable? I know that I don't want to run it in it's current state.
Thoughts, please!
Mike
1953 3100
The Gray Ghost
My Project journal
Moderated by  Phak1
